Car Brands
Car Manufacturers
Hyundai
Fuel Consumption
<blockquote data-quote="saolabi" data-source="post: 579500" data-attributes="member: 12932"><p>Usually its because of the following:- </p><p>1.air filter is filthy </p><p>2.larger wheels means extra weight(even an inch[X4wheels] makes a difference)</p><p>3.too much hot air in the engine compartment(more hot air means using up more fuel because less oxygen to combust).</p><p>That is why on rainy days, you save more fuel due to cooler air available. On hot days, uses up more fuel 4.time to have an overhaul, maybe??</p><p></p><p>Anyway, one month has passed since you wrote this thread. How is the fuel comsumption nowadays?</p></blockquote><p></p>
[QUOTE="saolabi, post: 579500, member: 12932"] Usually its because of the following:- 1.air filter is filthy 2.larger wheels means extra weight(even an inch[X4wheels] makes a difference) 3.too much hot air in the engine compartment(more hot air means using up more fuel because less oxygen to combust). That is why on rainy days, you save more fuel due to cooler air available. On hot days, uses up more fuel 4.time to have an overhaul, maybe?? Anyway, one month has passed since you wrote this thread. How is the fuel comsumption nowadays? [/QUOTE]
R35 Used Titanium Exhaust
BAIC D20 made its debut in Malaysia – CKD, EEV-status!
Beijing Auto International Corporation or BAIC has officially launched the D20, a 5-door hatchback with styling said to...
who intrest to let Japanese tuner o setting yr car n mgmt?
http://www.zerotohundred.com/newforums/showthread.php?p=1154691#post1154691
Blitz DUAL Turbo Timer wiring
ok..i got a timer n need to know d wiring how it works...
got two bunch wires....
1st bunch: green =?
Red =ACC (+)
Blue =?
Black = ground (-)
2nd bunch : orange=?
Purple = Handbrake
white= ?
and another hose i...
Car Brands
Car Manufacturers
Hyundai
Fuel Consumption
