Car Brands
Car Manufacturers
Mazda/Ford
FSE fuel pressure setting for b8
<blockquote data-quote="lynx_210" data-source="post: 677726" data-attributes="member: 12775"><p>a diffren car hv diffren setting i guess coz my using same but if i set as 38psi it will b toooooo reach for my car so now i set as 30+ near to 31 psi only then running ok ........ so maybe u need to do dyno with a good sifu to help u set .....</p><p>Hope this will hepl Cheers.....</p></blockquote><p></p>
[QUOTE="lynx_210, post: 677726, member: 12775"] a diffren car hv diffren setting i guess coz my using same but if i set as 38psi it will b toooooo reach for my car so now i set as 30+ near to 31 psi only then running ok ........ so maybe u need to do dyno with a good sifu to help u set ..... Hope this will hepl Cheers..... [/QUOTE]
david tao
Gimme that sleepy eyes!
u wanna that sleepy eyes in ur 2? try this trick !
1. if u notice there are three light lever;
a) turn one nothing happen
b) turn two small light on
c) turn three ur lights pop up
ok here is the trick, turn to (C)...
Ringing sound from clutch
As most of you would've known, by using a metal clutch (single, twins, triple etc) it would give a ringing sound when the clutch pedal is depressed. Once the clutch engages and in gear, the noise would no longer be...
how is the skyline 350gt?
how is the skyline 350gt? how do u guys comment this car??? sorry, my english poor, i saw this car exterior is not bad, quite nice.:proud:
Car Brands
Car Manufacturers
Mazda/Ford
