Main Forums
Car Talk
Forced Induction & Engine Management
feeling after banana manifold
<blockquote data-quote="jinkl" data-source="post: 2496794" data-attributes="member: 3008"><p>if u install wastegate , the engine will blow laaaa hehehhehehe</p><p>, nothing will happen to the engine la , no diffrence u install wastegate or no wastegate</p><p></p><p></p><p>and someppl saying air fuel ratio will be affected cos of changing header ,</p><p>as i believe , we all run on MAF , unless some of u already on standalones</p><p>if we are using MAF sensors , if the turbo is spooling faster for low end or giving more top end or whtever , ur air flows thru the MAF , MAF calculates the air , in the mapping vs RPM n etc , gives out the fueling for the engine , so y must there be a retune for ? stock ecu should be ok , bt 9krpm , errr do u know ur stock turbo dies at 6.5krpm for td05's , if u r on a drag race , the guy who shifted at 6.5krpm would be advance of u if u waited till 9krpm :D</p><p>and as i know our stock 4g63 valve n springs are already floating at 9krpm thus giving u lesser power. a short route header + stiffer valve springs + high cams = power u need for high rev machine.</p></blockquote><p></p>
[QUOTE="jinkl, post: 2496794, member: 3008"] if u install wastegate , the engine will blow laaaa hehehhehehe , nothing will happen to the engine la , no diffrence u install wastegate or no wastegate and someppl saying air fuel ratio will be affected cos of changing header , as i believe , we all run on MAF , unless some of u already on standalones if we are using MAF sensors , if the turbo is spooling faster for low end or giving more top end or whtever , ur air flows thru the MAF , MAF calculates the air , in the mapping vs RPM n etc , gives out the fueling for the engine , so y must there be a retune for ? stock ecu should be ok , bt 9krpm , errr do u know ur stock turbo dies at 6.5krpm for td05's , if u r on a drag race , the guy who shifted at 6.5krpm would be advance of u if u waited till 9krpm :D and as i know our stock 4g63 valve n springs are already floating at 9krpm thus giving u lesser power. a short route header + stiffer valve springs + high cams = power u need for high rev machine. [/QUOTE]
david tao
Charging Ahead - BMW Malaysia launches new Charging Bays at Bangsar Shopping Centre
how do you open the headlight cover?
i wanna retrofit waja's projector lenses onto my myvi's sportlights. but first of all how to split the sportlight's lens & housing ah? kenot ar?
how you ppl do it? searched adi, some of you guys say put in oven but...
AutoFoam vs DIY Insulation Foam... pls read!
Photos listing below -
http://www.autoworld.com.my/photoalbum/member/uploadEditPhoto.asp?AID=4450
Dear All Forum DIY fans,
As you know I was the one started the question on AutoFoam. I saw the AD at a local Mag &...
Main Forums
Car Talk
