Main Forums
Car Talk
Car Modification
Fairlady piston
<blockquote data-quote="Havok_KiD" data-source="post: 3522533" data-attributes="member: 23597"><p>i am wondering why are u having so much issue with VG piston </p><p>i have been running a 2.2l crank with vg30 piston.....whacking on gt30r turbo samo</p><p>i am using 1.5mm metal gasket...all the way till i sold my engine it was working fine...</p><p>there would be only 2 reason for me if the piston melt at the side is </p><p>1) your fuel is not enough to support your hp</p><p>2) your tuning or its been set up rongly</p><p>as far as i know vg piston can take high pressure and i was whacking at 1.5bar happily...</p><p></p><p>anyway its my 2 cents bro</p></blockquote><p></p>
[QUOTE="Havok_KiD, post: 3522533, member: 23597"] i am wondering why are u having so much issue with VG piston i have been running a 2.2l crank with vg30 piston.....whacking on gt30r turbo samo i am using 1.5mm metal gasket...all the way till i sold my engine it was working fine... there would be only 2 reason for me if the piston melt at the side is 1) your fuel is not enough to support your hp 2) your tuning or its been set up rongly as far as i know vg piston can take high pressure and i was whacking at 1.5bar happily... anyway its my 2 cents bro [/QUOTE]
Msd
Has anyone tried MSD products on mivec 4g92 gen2? Any suggestions? :)
Isuzu dealers collect RM22,000 for Japan quake victims
http://www.zerotohundred.com/?attachment_id=21109
Isuzu Malaysia’s network of local dealers have rallied together to raise RM22,000 in aid of the victims of the earthquake in Japan. The funds gathered was handed...
Renderings: New Mercedes CLK
Look at it, it’s as if it cant make up its mind whether it’s a smaller 2door E-Class or a bigger 2door C-Class or a pointier 2door S-Class. I...
Main Forums
Car Talk
Car Modification
Fairlady piston
