Car Clubs
Car Club Categories
The Malaysian Skyline Club
F-con navigator...
<blockquote data-quote="airtreknic" data-source="post: 3308799" data-attributes="member: 49591"><p>This device is possible to act as a monitor for various sensor functions in the vehicle by connecting it with the F-CON SZ or VPro</p><p></p><p>MONITORING FUNCTION</p><p>Engine RPM: Displays the engine RMP power supply voltage. Display Battery voltage.</p><p></p><p>Air Flow output value: Display the below information according to the following,</p><p></p><p>Hot wiring Type = Voltage</p><p></p><p>Carlman = Frequency</p><p></p><p>Intake Air Pressure = Voltage of pressure sensor</p><p></p><p>Ratio of air to fuel: Display the ratio or percentage of air & fuel.</p><p></p><p>Injector opening ratio: Display the opening ratio of injector.</p><p></p><p>Circulating Water Temperature: Displays the water temperature of the circulating coolant water.</p><p></p><p>Fuel Revision Value: Displays the Fuel Revision/Compensation Value which is adjusted by the F-Con SZ.</p><p></p><p>Ignition Revision Value: Displays Ignition Revision/Compensation which is adjusted by the F-Con SZ.</p><p></p><p>Intake Air Pressure: Displays boost pressures.</p><p></p><p>Speed: Displays driving speed (* This function is not applicable to some vehicle models).</p><p></p><p>EDITING FUNCTION</p><p></p><p>Fuel Revision Value: Edits the Fuel Revision/Compensation Value by using the F-Con SZ's revision map.</p><p></p><p>Ignition Revision Value: Edits the Ignition Revision/Compensation Value by using the F-Con SZ's revision map.</p><p></p><p>EIDS: Switching on/off the EIDS function.</p><p></p><p>FCD: Switching on/off the EIDS function.</p></blockquote><p></p>
[QUOTE="airtreknic, post: 3308799, member: 49591"] This device is possible to act as a monitor for various sensor functions in the vehicle by connecting it with the F-CON SZ or VPro MONITORING FUNCTION Engine RPM: Displays the engine RMP power supply voltage. Display Battery voltage. Air Flow output value: Display the below information according to the following, Hot wiring Type = Voltage Carlman = Frequency Intake Air Pressure = Voltage of pressure sensor Ratio of air to fuel: Display the ratio or percentage of air & fuel. Injector opening ratio: Display the opening ratio of injector. Circulating Water Temperature: Displays the water temperature of the circulating coolant water. Fuel Revision Value: Displays the Fuel Revision/Compensation Value which is adjusted by the F-Con SZ. Ignition Revision Value: Displays Ignition Revision/Compensation which is adjusted by the F-Con SZ. Intake Air Pressure: Displays boost pressures. Speed: Displays driving speed (* This function is not applicable to some vehicle models). EDITING FUNCTION Fuel Revision Value: Edits the Fuel Revision/Compensation Value by using the F-Con SZ's revision map. Ignition Revision Value: Edits the Ignition Revision/Compensation Value by using the F-Con SZ's revision map. EIDS: Switching on/off the EIDS function. FCD: Switching on/off the EIDS function. [/QUOTE]
R35 Used Titanium Exhaust
"What Machines Dream Of" - Ars Electronica at VW Berlin
Side by side to the Bugatti Showroom, VW has collaborated with Ars Electronica museum of Linz, Austria, to showcase the future of automobiles by VW. The exhibition was held in the Automobil Forum Unter den Linden at...
Seeking for Lexus Owner
Hi Guys....
Looking for all our Lexus for IS, GS, LS owner here...
anyone from ZTH?
Nissan GT-R
http://img219.imageshack.us/img219/4573/gtr2ni0.gif
http://img208.imageshack.us/img208/9980/gtr1sf0.gif
Best Car magazine in Japan is showing off a couple of pictures of the upcoming GT-R and...
Car Clubs
Car Club Categories
F-con navigator...
