Main Forums
Car Talk
evo 9 handling efficiency
<blockquote data-quote="vr2turbo" data-source="post: 1064245044" data-attributes="member: 92229"><p>If you did normal alignment the shop should be able to tell if the camber and caster are out....</p></blockquote><p></p>
[QUOTE="vr2turbo, post: 1064245044, member: 92229"] If you did normal alignment the shop should be able to tell if the camber and caster are out.... [/QUOTE]
engine flash light!!
i need help...my engine flash light keeps coming out
i went to the workship that i normally go --> they stated it normally sensor problem....they then remove the flash light using cpu/ecu......my car drive normally...
German Tuner B&B Creates 362hp Monster Golf R
https://www.zerotohundred.com/wp-content/uploads/2010/02/VW-Golf-R-BB-3-3.jpg
The Golf R already makes a pretty hefty 270hp at all four wheels, that is a lot for a car the size of the Golf but in the wild pursuit of...
Conrod CA18 turbo; NA; single & twin cam, same?
Sorry for asking newbie question here, but been searching few halfcut shop lately, but get no info related to this conrod.
I wanna swap my gsr conrod to this CA18 conrod, but dunno which 1 to go. Izit all the CA18...
Main Forums
Car Talk
