Main Forums
Car Talk
Car Modification
Enlarge piping after pnp
<blockquote data-quote="wirafly" data-source="post: 972345" data-attributes="member: 10859"><p>if you looking for low end tork, you should consider raise compression ratio either by skim engine head or install thinner metal gasket...higher compression ratio give better tork....no joke...but u have to be becarefull on maintaining engine temp after increase compression ratio</p></blockquote><p></p>
[QUOTE="wirafly, post: 972345, member: 10859"] if you looking for low end tork, you should consider raise compression ratio either by skim engine head or install thinner metal gasket...higher compression ratio give better tork....no joke...but u have to be becarefull on maintaining engine temp after increase compression ratio [/QUOTE]
david tao
HPC MAM 4 Hour endure marks first circuit-sanctioned event my MAM
https://www.zerotohundred.com/wp-content/uploads/2011/05/hpc-600x450.jpg
The HPC MAM 4 Hour Endurance 2011 will mark the first ever circuit event sanctioned by the Motorsport Association of Malaysia (MAM), marking a...
A tale of two racers pursuing their dreams at TOC
Above: Practice makes perfect for Fahmi at the pretigious PFX
. How old do you have to be in order to become an...
power fc for evo 8!! map!!!
selling apexi power fc for evo 8 with harness and commander....map sensor included....this unit is running on mapping..not airflow..rm2700nego..
please contact me at 012-6077811...dun...
Main Forums
Car Talk
Car Modification
