Car Brands
Car Manufacturers
Honda
Engine Swap
<blockquote data-quote="basahboy" data-source="post: 575547" data-attributes="member: 9696"><p>Got some info here to share....</p><p></p><p></p><p>To identify type r...</p><p>1. agreed on the mfg date as you all mentioned...</p><p>2. you can check that all type r has a green marking on the top left of the engine head belakang skit...it will wear off but mesti ada skit green le..</p><p>3. usually the engine will be left open on the intake manifold holes and stuff with paper....open it up and u can see the port and polist...all type r engines are port and polish by hand by honda engineers....</p><p>4. also bring a torch lite and see the valves...the type r valves punye tengkuk lain skit from the rest...</p><p></p><p>And also....</p><p></p><p>There are 60 changes made into GSR to make a type r....overall weight difference is 45kgs...type r is lighter....</p><p></p><p>I am quoting this from a honda engineer in the Japanese Carboy magazine....</p><p></p><p>hope this helps...</p></blockquote><p></p>
[QUOTE="basahboy, post: 575547, member: 9696"] Got some info here to share.... To identify type r... 1. agreed on the mfg date as you all mentioned... 2. you can check that all type r has a green marking on the top left of the engine head belakang skit...it will wear off but mesti ada skit green le.. 3. usually the engine will be left open on the intake manifold holes and stuff with paper....open it up and u can see the port and polist...all type r engines are port and polish by hand by honda engineers.... 4. also bring a torch lite and see the valves...the type r valves punye tengkuk lain skit from the rest... And also.... There are 60 changes made into GSR to make a type r....overall weight difference is 45kgs...type r is lighter.... I am quoting this from a honda engineer in the Japanese Carboy magazine.... hope this helps... [/QUOTE]
R35 Used Titanium Exhaust
Charging Ahead - BMW Malaysia launches new Charging Bays at Bangsar Shopping Centre
New&Fresh MCR R35 GTR vs FEED RX-7 FD3S Final Battle HV Vol 101
YouTube- Hot Version Vol.101 4/11
YouTube - Hot Version Vol.101 4/11
And Tsuchiya in Malaysia (Malaysia atsui desu ne ?
), MME Sepang J's Racing review...
A question for the chop shop experts :)
Hi guys,
I'm a total newbie as you can see. Didn't know which section to post this question under hope you guys don't mind.
Saw a website of this guy from the UKs who transplanted a 6A13TT into his FTO. Was just...
sn964444
Car Brands
Car Manufacturers
Honda
Engine Swap
