Main Forums
Car Talk
Car Modification
engine suddenly jerk
<blockquote data-quote="Turbomaster1" data-source="post: 3659937" data-attributes="member: 43604"><p>the only way test fuel pump is pressure test....connect a pressure gauge in between the fuel filter and fuel rail......pressure should go up as you rev harder....off engine... it should stay for while....</p><p></p><p>jerking prob normally happens if got coil/ plug cable damage......injectors do not normally fail unless it has been unused for a while.....</p><p></p><p>engine tuning also can effect during acceleration....if got management....</p><p></p><p>cheers</p></blockquote><p></p>
[QUOTE="Turbomaster1, post: 3659937, member: 43604"] the only way test fuel pump is pressure test....connect a pressure gauge in between the fuel filter and fuel rail......pressure should go up as you rev harder....off engine... it should stay for while.... jerking prob normally happens if got coil/ plug cable damage......injectors do not normally fail unless it has been unused for a while..... engine tuning also can effect during acceleration....if got management.... cheers [/QUOTE]
R35 Used Titanium Exhaust
Reservoir tank problem ?
Helo ,
I have recently noticed that the water level of my car reservoir tank is dropping whenever I drive .
So I top it up daily , usually will be less than a half of the tank .
I tried figuring out the problem and...
AR 80 (from sr20)
sorry if i post it at the wrong section ler~
just wanna know if anyone used AR 80 (from sr20) before?
the size compare to td05?
the responds? compare to td05? (or other similar turbine)
the review from some of the...
Altezza for sale....
I am letting go my ride. Details as follow:
Basics:
- Year 2001; Registered 2006
- Beams RS200 3S-GE, 5 A/T triptonic, silver colour, nice number
- L-edition (GPS navigational, 4 airbags, beige interior, original...
Main Forums
Car Talk
Car Modification
