Car Brands
Car Manufacturers
Mazda/Ford
engine oil
<blockquote data-quote="spanker" data-source="post: 901839" data-attributes="member: 14479"><p>the wider the range of the numbers, the thicker the oil. For instance, 15-50 is much thicker than 10-40, which is thicker than 10-30. the W on, lets say 10W-30, denotes winter usage (useless in m'sia).</p><p></p><p>The reason where there's a range is because those oil are multigrade viscosity. Long time ago, they had single grade oil, like 5W, 10, 30W... well you get my meaning. So a wider range gives you a wider operating temperature range, but it's not as smooth. Now i think only airplanes and heavy industries use those single grade oils.</p><p></p><p>Synthetics are smoother than organics/minerals, with higher shearing tolerance than the latter.</p><p></p><p>I'm just spitting out what I learned about motor oil on the internets, heheh. Did some research on it because I had no idea what oil to put in my car last time. Mobil 1 is the best apparently.</p></blockquote><p></p>
[QUOTE="spanker, post: 901839, member: 14479"] the wider the range of the numbers, the thicker the oil. For instance, 15-50 is much thicker than 10-40, which is thicker than 10-30. the W on, lets say 10W-30, denotes winter usage (useless in m'sia). The reason where there's a range is because those oil are multigrade viscosity. Long time ago, they had single grade oil, like 5W, 10, 30W... well you get my meaning. So a wider range gives you a wider operating temperature range, but it's not as smooth. Now i think only airplanes and heavy industries use those single grade oils. Synthetics are smoother than organics/minerals, with higher shearing tolerance than the latter. I'm just spitting out what I learned about motor oil on the internets, heheh. Did some research on it because I had no idea what oil to put in my car last time. Mobil 1 is the best apparently. [/QUOTE]
R35 Used Titanium Exhaust
bodykits for NA
hi! Bro
i m looking bodykits for NA
anyone recommend at KL and selangor area
thanks
FS: Mitsubishi Evolution 7
Year : 2001
Color : white
Price : RM 165,000.00
Contact: 012 2083222 (No Sms)
Loan around : RM 100,000.00
Others: Sunroof / Accident free
* No parts for individual selling or exchange *
Exterior...
Wira Dani Puts Hopes On Radical For Malaysian Super Series
WIRA DANI PUTS HOPES ON RADICAL FOR MALAYSIAN SUPER SERIES
Malaysia’s top racing driver, Wira Dani Daim will be making his...
Car Brands
Car Manufacturers
Mazda/Ford
engine oil
