Car Clubs
Car Club Categories
RE Club Malaysia
Engine OIL Top UP?
<blockquote data-quote="joe13" data-source="post: 1222898" data-attributes="member: 13377"><p>Yes, you can just top up engine oil to the appropriate levels, but make sure u use the same oil, if not, same ratings. i think u got a leak some where, check ur pan or oil filter pedestal for leaks. other weak points will be oil coolant lines.</p></blockquote><p></p>
[QUOTE="joe13, post: 1222898, member: 13377"] Yes, you can just top up engine oil to the appropriate levels, but make sure u use the same oil, if not, same ratings. i think u got a leak some where, check ur pan or oil filter pedestal for leaks. other weak points will be oil coolant lines. [/QUOTE]
david tao
Ap Racing dealer in kl?
anyone know about shop that carry the above item?
R32 Gts-t
just wondering, is it worth gettin the ride? a GTR will be too expensive...... and hard to get loan.........
Post Your Technical Q&a Stuffs Here
Guys... as the title stated above. This tread shall have no crap. Serious Q&A section. :) Turbo Sifus can help with related questions here.
CHeerS!
vr2turbo
Car Clubs
Car Club Categories
RE Club Malaysia
Engine OIL Top UP?
