Main Forums
Car Talk
engine oil analysis for the poor
<blockquote data-quote="upontheriversky" data-source="post: 1063791611" data-attributes="member: 59480"><p><strong>Blotter Spot Test</strong></p><p></p><p>Objective: oxidation products, sludge formation, dispersancy failure, glycol contamination, water contamination, fuel dilution, and high levels of particles.</p><p></p><p>1. place a drop or 2 of used oil on a good heavy white card (i.e. business card)</p><p>2. suspend the card, use 2 pencils on a table and place it so both ends of card resting on the pencils</p><p>3. wait couple of minutes until the oil drop is fully absorbed by the card </p><p>4. start evaluation:</p><p></p><p>- A colorless spot or slight yellow outer ring - "good" oil.</p><p>- A dense, dark deposit zone – Dispersancy failure</p><p>- A black, pasty zone – Glycol (Antifreeze) in your oil</p><p>- A dark center with distinct outer ring – Severely oxidized oil</p><p>- A dark center with surrounding rings – Fuel in oil</p><p></p><p><strong>Crackle Test</strong></p><p></p><p>Objective: to test for water ingression into oil from condensation. normally happens on cars with frequent short trips or on cars not being run for long period</p><p></p><p>1. fuel in oil can temper with test result, so do blotter spot test first to make sure.</p><p>2. drop a small quantity of used oil on heated frying pan which is already hot enough to boil off any water</p><p>3. if there is water present in oil, you should hear crackle noise from water being boiled off</p><p>4. if no crackle, means no significant amount of water present</p><p></p><p><strong>Used Filter Inspection</strong></p><p></p><p>Objective: to check for significant engine wear and tear</p><p></p><p>1. Cut open the filter</p><p>2. if large amount of metal shavings present, with some of it being fairly large. serious wear issues may have occured.</p><p>3. check for "blobs" or "gummy" oil on the filter media for presence of sludge </p><p></p><p><strong>Oil On Water</strong></p><p></p><p>Objective: to check for contamination or oxidation</p><p></p><p>1. new oil will bead up when dropped on water surface</p><p>2. if the oil drop spreads out, it means ur oil is either contaminated or already oxidized</p><p></p><p></p><p><strong>The Rub Test</strong></p><p></p><p>Objective: to check for oil contamination</p><p></p><p>1. do this test shortly after driving, make sure oil is not too hot that it will burn your hands</p><p>2. take a drop of oil on dipstick and rub it between fingers.</p><p>3. if it feels fairly "grainy" like there are tiny fibres present, change the oil as it is pretty contaminated already</p><p></p><p></p><p><strong>The Smell Test</strong></p><p></p><p>Objective: to check for oil oxidation</p><p></p><p>1. take a new bottle of engine oil u have used on last oil change and smell it. this is the smell of a new and in good condition engine oil</p><p>2. take a drop of ur used oil and smell it, if it smells more like "burnt" compared to the new oil, it means oxidation has occured</p><p>3. but take note, some oxidation is normal, it is just an indication that ur used oil is not as good as new.</p><p></p><p></p><p>All the above tests are not as precise and accurate as a proper UOA but it will give u a cheap, fast and reliable way of knowing the general state of ur engine oil. it is also good for rough comparison between different engine oils you are using</p><p></p><p>So you know whether the oil can still be used or it will need to be changed immediately</p><p></p><p>reference: themotoroilevaluator.com</p></blockquote><p></p>
[QUOTE="upontheriversky, post: 1063791611, member: 59480"] [B]Blotter Spot Test[/B] Objective: oxidation products, sludge formation, dispersancy failure, glycol contamination, water contamination, fuel dilution, and high levels of particles. 1. place a drop or 2 of used oil on a good heavy white card (i.e. business card) 2. suspend the card, use 2 pencils on a table and place it so both ends of card resting on the pencils 3. wait couple of minutes until the oil drop is fully absorbed by the card 4. start evaluation: - A colorless spot or slight yellow outer ring - "good" oil. - A dense, dark deposit zone – Dispersancy failure - A black, pasty zone – Glycol (Antifreeze) in your oil - A dark center with distinct outer ring – Severely oxidized oil - A dark center with surrounding rings – Fuel in oil [B]Crackle Test[/B] Objective: to test for water ingression into oil from condensation. normally happens on cars with frequent short trips or on cars not being run for long period 1. fuel in oil can temper with test result, so do blotter spot test first to make sure. 2. drop a small quantity of used oil on heated frying pan which is already hot enough to boil off any water 3. if there is water present in oil, you should hear crackle noise from water being boiled off 4. if no crackle, means no significant amount of water present [B]Used Filter Inspection[/B] Objective: to check for significant engine wear and tear 1. Cut open the filter 2. if large amount of metal shavings present, with some of it being fairly large. serious wear issues may have occured. 3. check for "blobs" or "gummy" oil on the filter media for presence of sludge [B]Oil On Water[/B] Objective: to check for contamination or oxidation 1. new oil will bead up when dropped on water surface 2. if the oil drop spreads out, it means ur oil is either contaminated or already oxidized [B]The Rub Test[/B] Objective: to check for oil contamination 1. do this test shortly after driving, make sure oil is not too hot that it will burn your hands 2. take a drop of oil on dipstick and rub it between fingers. 3. if it feels fairly "grainy" like there are tiny fibres present, change the oil as it is pretty contaminated already [B]The Smell Test[/B] Objective: to check for oil oxidation 1. take a new bottle of engine oil u have used on last oil change and smell it. this is the smell of a new and in good condition engine oil 2. take a drop of ur used oil and smell it, if it smells more like "burnt" compared to the new oil, it means oxidation has occured 3. but take note, some oxidation is normal, it is just an indication that ur used oil is not as good as new. All the above tests are not as precise and accurate as a proper UOA but it will give u a cheap, fast and reliable way of knowing the general state of ur engine oil. it is also good for rough comparison between different engine oils you are using So you know whether the oil can still be used or it will need to be changed immediately reference: themotoroilevaluator.com [/QUOTE]
david tao
Uber Volvo to replace human drivers with this autonomous XC90!
https://www.zerotohundred.com/wp-content/uploads/2016/08/194846_Volvo_Cars_and_Uber_join_forces_to_develop_autonomous_driving_cars-800x450-700x394.jpg
The people at ride-hailing app companies like Uber and Lyft have...
why Subaru V8..not Evo7..???
Dear All the Senior2 for the Subaru.........
I wanted to buy Evo7 or Subaru V8, but dun know which one is better...
Why i should buy the Subaru V8 compared to E7???..........
can anybody give me the suggestion which...
Ori top secret bonnet pin....brand new!
anyone top secret bonnet pin without lock!
RM450nego:_:
012 669 0525
Welcome to the official TOP SECRET Homepage
Main Forums
Car Talk
