Main Forums
Car Talk
Forced Induction & Engine Management
EMS Info , Microtech , Haltech , Apexi , Motec
<blockquote data-quote="jinkl-" data-source="post: 735195" data-attributes="member: 10049"><p><strong>A</strong> <a href="http://www.emergent.com.au/200sx/ecudata.html#A1" target="_blank"><span style="color: #800080">Apexi PowerFC</span></a> <a href="http://www.emergent.com.au/200sx/ecudata.html#A2" target="_blank"><span style="color: #800080">Autronic SMC</span></a> <a href="http://www.emergent.com.au/200sx/ecudata.html#A3" target="_blank"><span style="color: #800080">Autronic SM2</span></a> <strong>E</strong> <a href="http://www.emergent.com.au/200sx/ecudata.html#E1" target="_blank"><span style="color: #800080">EMS Dual Sport</span></a> <strong>H</strong> <a href="http://www.emergent.com.au/200sx/ecudata.html#H1" target="_blank"><span style="color: #800080">Haltec E6K</span></a><a href="http://www.emergent.com.au/200sx/ecudata.html#H2" target="_blank"><span style="color: #800080">Haltech E6H/M</span></a><a href="http://www.emergent.com.au/200sx/ecudata.html#H3" target="_blank"><span style="color: #800080">Haltech E6S</span></a><a href="http://www.emergent.com.au/200sx/ecudata.html#HA1" target="_blank"><span style="color: #800080">Hawk EC21</span></a><strong>L</strong><a href="http://www.emergent.com.au/200sx/ecudata.html#L1" target="_blank"><span style="color: #800080">Link Plug-In</span></a><a href="http://www.emergent.com.au/200sx/ecudata.html#L2" target="_blank"><span style="color: #800080">Link Wire-In</span></a> <strong>M</strong>Microtech Digi<a href="http://www.emergent.com.au/200sx/ecudata.html#M1" target="_blank"><span style="color: #800080">MoTeC M4 Clubman</span></a> <a href="http://www.emergent.com.au/200sx/ecudata.html#M2" target="_blank"><span style="color: #800080">MoTeC M4 Pro</span></a> <a href="http://www.emergent.com.au/200sx/ecudata.html#M3" target="_blank"><span style="color: #800080">MoTeC M48 Clubman</span></a> <a href="http://www.emergent.com.au/200sx/ecudata.html#M4" target="_blank"><span style="color: #800080">MoTeC M48 Pro</span></a> <a href="http://www.emergent.com.au/200sx/ecudata.html#M5" target="_blank"><span style="color: #800080">MoTeC M800</span></a> <a href="http://www.emergent.com.au/200sx/ecudata.html#M6" target="_blank"><span style="color: #800080">Motec M8 Pro</span></a> <strong>N</strong><a href="http://www.emergent.com.au/200sx/ecudata.html#N1" target="_blank"><span style="color: #800080">Nissan ECCS (JECS)</span></a> <strong>W</strong><a href="http://www.emergent.com.au/200sx/ecudata.html#W1" target="_blank"><span style="color: #800080">Wolf 3D v3.0</span></a> <strong><a href="http://www.apexi.co.jp/" target="_blank"><span style="color: #800080">Apexi</span></a> PowerFC</strong></p><p></p><p>CPUNEC 78P334 @ 16MHzMax Cylinders6Fuel Maps20Ignition Maps20Load Points per Map20Total Fuel Points400Total Ignition Points400Fuel Correction Maps or FactorsCoolant TempIgnition Correction Maps or FactorsCoolant TempInjector Outputs6Ignition Outputs6Auxiliary Inputs0Auxiliary Outputs0O2 SensorYes (OEM)Closed Loop OperationYesData LoggingNoBoost ControlYes (Optional)Traction/Launch ControlNoNitrous ManagementNoVTEC ControlNoAnti-LagNoFlat-ShiftUnknownPC ProgrammableNoHandset ProgrammableYes - Controller not included<strong> </strong></p><p><strong></strong></p><p><strong>Autronic SMC</strong></p><p></p><p>CPUIntel 16-bit @ 16MHzMax Cylinders16Fuel Maps32Ignition Maps32Load Points per Map16Total Fuel Points512Total Ignition Points512Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Throttle Pump, Injector TrimIgnition Correction Maps or FactorsCoolant Temp, Air Temp, AltitudeInjector Outputs8Ignition Outputs4Auxiliary Inputs1Auxiliary OutputsMax 5 (Depending on number of injectorrs)O2 SensorYes (Wideband)Closed Loop OperationYesData LoggingYesBoost ControlYesTraction/Launch ControlNoNitrous ManagementNoVTEC ControlIndirect (RPM/Load Operated output)Anti-LagYesFlat-ShiftYesPC ProgrammableYes - DOSHandset ProgrammableNo<strong>Autronic SM2</strong></p><p></p><p>CPUIntel 16-bit @ 16MHzMax Cylinders16Fuel Maps32Ignition Maps32Load Points per Map16Total Fuel Points512Total Ignition Points512Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Throttle Pump, Injector TrimIgnition Correction Maps or FactorsCoolant Temp, Air Temp, AltitudeInjector Outputs8Ignition Outputs4Auxiliary Inputs3Auxiliary Outputs9O2 SensorYesClosed Loop OperationYesData LoggingYesBoost ControlYesTraction/Launch ControlYesNitrous ManagementYesVTEC ControlIndirect (RPM/Load Operated output)Anti-LagYesFlat-ShiftYesPC ProgrammableYes - DOSHandset ProgrammableNo<strong><a href="http://www.enginemanagementsystem.com/" target="_blank"><span style="color: #0000ff">EMS</span></a> Dual Sport I</strong></p><p></p><p>CPUMotorola 16-bitMax Cylinders16Fuel Maps26Ignition Maps26Load Points per Map3 + 16 Curve ModifiersTotal Fuel Points78 (excluding curve modifiers)Total Ignition Points78 (excluding curve modifiers)Fuel Correction Maps or FactorsCoolant temp, Air temp, Full throttle, Closed throttle, Battery voltage, Throttle pump, Fuel trim, Curve modifier, Barometric pressure, Variable injection resolution, Sync/Async injection resolution, Prediction algorithmIgnition Correction Maps or FactorsCoolant temp, Barometric presureInjector Outputs8Ignition Outputs4Auxiliary Inputs1Auxiliary Outputs4O2 SensorOptional (Wideband)Closed Loop OperationNoData LoggingYes (To laptop)Boost ControlYesTraction/Launch ControlNoNitrous ManagementYesVTEC ControlYesAnti-LagYesFlat-ShiftNoPC ProgrammableYes - WindowsHandset ProgrammableYes - Included<strong><a href="http://www.haltech.com.au/" target="_blank"><span style="color: #0000ff">Haltech</span></a> E6K</strong></p><p></p><p>CPUMotorola 68HC11K4 @ 16MHzMax Cylinders12Fuel Maps17 or 22Ignition Maps17 or 22Load Points per Map32Total Fuel Points544 or 704Total Ignition Points544 or 704Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Injector Phasing, Throttle Pump, Injector Trim, Barometric PressureIgnition Correction Maps or FactorsCoolant Temp, Air TempInjector Outputs8Ignition Outputs4Auxiliary Inputs2Auxiliary Outputs6O2 SensorYes (Wideband)Closed Loop OperationYesData LoggingYesBoost ControlYesTraction/Launch ControlYesNitrous ManagementYesVTEC ControlYesAnti-LagYesFlat-ShiftYesPC ProgrammableYes - DOSHandset ProgrammableNo<strong><a href="http://www.haltech.com.au/" target="_blank"><span style="color: #0000ff">Haltech</span></a> E6H/E6M</strong></p><p></p><p>CPUMotorola 68HC11K4 @ 16MHzMax Cylinders12Fuel Maps17 or 22Ignition Maps17 or 22Load Points per Map32Total Fuel Points544 or 704Total Ignition Points544 or 704Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Injector Phasing, Throttle Pump, Injector Trim, Barometric PressureIgnition Correction Maps or FactorsCoolant Temp, Air TempInjector Outputs8Ignition Outputs4Auxiliary Inputs2Auxiliary Outputs2O2 SensorYes (Wideband)Closed Loop OperationYesData LoggingYesBoost ControlYesTraction/Launch ControlYesNitrous ManagementYesVTEC ControlYesAnti-LagYesFlat-ShiftYesPC ProgrammableYes - DOSHandset ProgrammableNo<strong><a href="http://www.haltech.com.au/" target="_blank"><span style="color: #0000ff">Haltech</span></a> E6S</strong></p><p></p><p>CPUMotorola 68HC11E2 @ 8MHzMax Cylinders12Fuel Maps17 or 22Ignition Maps17 or 22Load Points per Map32Total Fuel Points544 or 704Total Ignition Points544 or 704Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Injector Phasing, Throttle Pump, Injector TrimIgnition Correction Maps or FactorsCoolant Temp, Air TempInjector Outputs4 or 8Ignition Outputs4Auxiliary Inputs2Auxiliary Outputs2O2 SensorYes (Wideband)Closed Loop OperationYesData LoggingYesBoost ControlYesTraction/Launch ControlYesNitrous ManagementYesVTEC ControlYesAnti-LagYesFlat-ShiftNoPC ProgrammableYes - DOSHandset ProgrammableNo<strong><a href="http://www.efihardware.com/" target="_blank"><span style="color: #0000ff">Hawk</span></a> EC21</strong></p><p></p><p>CPUUnknown @8MHzMax Cylinders Fuel Maps128Ignition Maps128Load Points per Map16Total Fuel Points2048Total Ignition Points2048Fuel Correction Maps or FactorsAir Temp, Coolant TempIgnition Correction Maps or FactorsCoolant Temp, Air TempInjector Outputs2Ignition Outputs4Auxiliary Inputs0Auxiliary Outputs2O2 SensorYesClosed Loop OperationUnknown (probably yes)Data LoggingNoBoost ControlNoTraction/Launch ControlNoNitrous ManagementNoVTEC ControlNoAnti-LagNoFlat-ShiftNoPC ProgrammableYes - DOSHandset ProgrammableNo<strong>Link Plug-In</strong></p><p></p><p>CPUUnknownMax Cylinders6Fuel Maps8Ignition Maps8Load Points per Map16Total Fuel Points128Total Ignition Points128Fuel Correction Maps or FactorsCoolant TempIgnition Correction Maps or FactorsCoolant TempInjector Outputs6Ignition Outputs4Auxiliary Inputs0Auxiliary Outputs0O2 SensorYes (OEM)Closed Loop OperationYesData LoggingOptionalBoost ControlYesTraction/Launch ControlNoNitrous ManagementNoVTEC ControlNoAnti-LagNoFlat-ShiftNoPC ProgrammableMinimal - Download Maps via comms programHandset ProgrammableYes - Optional<strong>Link Wire-In</strong></p><p></p><p>CPUUnknownMax Cylinders12Fuel Maps8Ignition Maps8Load Points per Map16Total Fuel Points128Total Ignition Points128Fuel Correction Maps or FactorsCoolant TempIgnition Correction Maps or FactorsCoolant TempInjector Outputs8Ignition Outputs4Auxiliary Inputs2Auxiliary Outputs4O2 SensorYes (Wideband)Closed Loop OperationYesData LoggingOptionalBoost ControlYesTraction/Launch ControlNoNitrous ManagementNoVTEC ControlYesAnti-LagNoFlat-ShiftNoPC ProgrammableMinimal - Download Maps via comms programHandset ProgrammableYes - Optional<strong><a href="http://www.motec.com.au/" target="_blank"><span style="color: #0000ff">MoTeC</span></a> M4 Clubman</strong></p><p></p><p>CPUMotorola 32-bit @ 33MHzMax Cylinders12Fuel Maps40Ignition Maps40Load Points per Map21Total Fuel Points840Total Ignition Points840Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Throttle Pump, Injector TrimIgnition Correction Maps or FactorsCoolant Temp, Air TempInjector Outputs4Ignition Outputs4Auxiliary Inputs2Auxiliary OutputsMax 3 (Depending on Number of Cylinders)O2 SensorYes (Narrow Band)Closed Loop OperationYesData LoggingOptionalBoost ControlYesTraction/Launch ControlOptionalNitrous ManagementYesVTEC ControlIndirect (RPM Operated output)Anti-LagNoFlat-ShiftNoPC ProgrammableYes - DOSHandset ProgrammableNo<strong><a href="http://www.motec.com.au/" target="_blank"><span style="color: #0000ff">MoTeC</span></a> M4 Pro</strong></p><p></p><p>CPUMotorola 32-bit @ 33MHzMax Cylinders12Fuel Maps40Ignition Maps40Load Points per Map21Total Fuel Points840Total Ignition Points840Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Throttle Pump, Injector TrimIgnition Correction Maps or FactorsCoolant Temp, Air TempInjector Outputs4Ignition Outputs4Auxiliary Inputs2Auxiliary OutputsMax 3 (Depending on Number of Cylinders)O2 SensorYes (Wideband)Closed Loop OperationYesData LoggingYesBoost ControlYesTraction/Launch ControlOptionalNitrous ManagementYesVTEC ControlIndirect (RPM Operated output)Anti-LagYesFlat-ShiftYesPC ProgrammableYes - DOSHandset ProgrammableNo<strong><a href="http://www.motec.com.au/" target="_blank"><span style="color: #0000ff">MoTeC</span></a> M48 Clubman</strong></p><p></p><p>CPUMotorola 32-bit @ 33MHzMax Cylinders12Fuel Maps40Ignition Maps40Load Points per Map21Total Fuel Points840Total Ignition Points840Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Throttle Pump, Injector TrimIgnition Correction Maps or FactorsCoolant Temp, Air TempInjector Outputs8Ignition Outputs2Auxiliary Inputs2Auxiliary OutputsMax 3 (Depending on Number of Cylinders)O2 SensorYes (Narrow Band)Closed Loop OperationYesData LoggingOptionalBoost ControlYesTraction/Launch ControlOptionalNitrous ManagementYesVTEC ControlIndirect (RPM Operated output)Anti-LagNoFlat-ShiftNoPC ProgrammableYes - DOSHandset ProgrammableNo<strong><a href="http://www.motec.com.au/" target="_blank"><span style="color: #0000ff">MoTeC</span></a> M48 Pro</strong></p><p></p><p>CPUMotorola 32-bit @ 33MHzMax Cylinders12Fuel Maps40Ignition Maps40Load Points per Map21Total Fuel Points840Total Ignition Points840Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Throttle Pump, Injector TrimIgnition Correction Maps or FactorsCoolant Temp, Air TempInjector Outputs8Ignition Outputs2Auxiliary Inputs2Auxiliary OutputsMax 3 (Depending on Number of Cylinders)O2 SensorYes (Wideband)Closed Loop OperationYesData LoggingYesBoost ControlYesTraction/Launch ControlOptionalNitrous ManagementYesVTEC ControlIndirect (RPM Operated output)Anti-LagYesFlat-ShiftYesPC ProgrammableYes - DOSHandset ProgrammableNo<strong><a href="http://www.motec.com.au/" target="_blank"><span style="color: #0000ff">MoTeC</span></a> M800</strong></p><p></p><p>CPUMotorola 32-bit @ 66MHz (not confirmed)Max Cylinders12Fuel Maps40Ignition Maps40Load Points per Map21Total Fuel Points840Total Ignition Points840Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Throttle Pump, Injector TrimIgnition Correction Maps or FactorsCoolant Temp, Air TempInjector Outputs8 (Unused outputs can be used as general purpose)Ignition Outputs6 (Unused outputs can be used as general purpose)Auxiliary Inputs4Auxiliary Outputs8Temperature Inputs6Voltage Inputs8O2 SensorYes (Dual Wideband)Closed Loop OperationYesData LoggingYesBoost ControlYesTraction/Launch ControlYesNitrous ManagementYesVTEC ControlIndirect (RPM Operated output)Anti-LagYesFlat-ShiftYesPC ProgrammableYes - DOSHandset ProgrammableNo<strong><a href="http://www.motec.com.au/" target="_blank"><span style="color: #0000ff">MoTeC</span></a> M8 Pro</strong></p><p></p><p>M8 Has been made obsolete by the M800, but it's still a good reference.</p><p></p><p>CPUMotorola 32-bit @ 33MHzMax Cylinders12Fuel Maps40Ignition Maps40Load Points per Map21Total Fuel Points840Total Ignition Points840Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Throttle Pump, Injector TrimIgnition Correction Maps or FactorsCoolant Temp, Air TempInjector Outputs4Ignition Outputs4Auxiliary Inputs2Auxiliary OutputsMax 3 (Depending on Number of Cylinders)O2 SensorYes (Wideband)Closed Loop OperationYesData LoggingYesBoost ControlYesTraction/Launch ControlYesNitrous ManagementYesVTEC ControlIndirect (RPM Operated output)Anti-LagYesFlat-ShiftYesPC ProgrammableYes - DOSHandset ProgrammableNo<strong>Nissan ECCS (JECS)</strong></p><p></p><p>CPUMotorola 16-bitMax Cylinders6Fuel Maps16 Low-Octane, 16 High-OctaneIgnition Maps16 Low-Octane, 16 High-OctaneLoad Points per Map16Total Fuel Points256 Low-Octane, 256 High-OctaneTotal Ignition Points256 Low-Octane, 256 High-OctaneFuel Correction Maps or FactorsWater Temp, Throttle Off, AccelerationIgnition Correction Maps or FactorsWater TempInjector Outputs6Ignition Outputs6Auxiliary Inputs0Auxiliary Outputs0O2 SensorYes (Narrow band)Closed Loop OperationYesData LoggingLimited (Fault Codes and Self-Learn)Boost ControlYesTraction/Launch ControlNoNitrous ManagementNoVTEC ControlNICSAnti-LagNoFlat-ShiftNoPC ProgrammableNoHandset ProgrammableLimited - Dealer/OEM CONSULT tool<strong><a href="http://www.wolfems.com.au/" target="_blank"><span style="color: #0000ff">Wolf</span></a> 3D v3.0</strong></p><p></p><p>CPUUnknownMax Cylinders12Fuel Maps16Ignition Maps16Load Points per Map8Total Fuel Points128Total Ignition Points128Fuel Correction Maps or FactorsCoolant Temp, AccelerationIgnition Correction Maps or FactorsCoolant Temp, AccelerationInjector Outputs4Ignition Outputs4Auxiliary InputsUnknownAuxiliary Outputs2O2 SensorYes (Narrow Band)Closed Loop OperationNoData LoggingOptionalBoost ControlYesTraction/Launch ControlNoNitrous ManagementNoVTEC ControlNoAnti-LagNoFlat-ShiftNoPC ProgrammableYes (Windows)Handset ProgrammableYes - Included</p><p style="text-align: left"></p> <p style="text-align: left">Microtech : </p> <p style="text-align: left"></p> <p style="text-align: left">Microtech LT10S (Replaces LTX8)</p> <p style="text-align: left">[841]$1,425.00nzhttp://www.japaneseperformance.co.nz/images/pixel_trans.gifhttp://www.japaneseperformance.co.nz/images/LT10Ssml.jpg</p> <p style="text-align: left"><span style="color: #0000ff">Click to enlarge</span> <a href="http://www.japaneseperformance.co.nz/images/LT10Ssml.jpg?osCsid=257fea11e0d46eef05ddf8d9dbe3695b" target="_blank"><img src="http://images/LT10Ssml.jpg" alt="" class="fr-fic fr-dii fr-draggable " style="" /></a></p> <p style="text-align: left"><a href="http://www.japaneseperformance.co.nz/images/LT10Ssml.jpg?osCsid=257fea11e0d46eef05ddf8d9dbe3695b" target="_blank">Click to enlarge</a><strong>Specification sheet:- </strong></p> <p style="text-align: left"><strong></strong></p> <p style="text-align: left"><strong>Kit Contents:-</strong></p> <p style="text-align: left">ECU</p> <p style="text-align: left">Flying Lead Wiring Loom (labeled)</p> <p style="text-align: left">Vacuum Hose</p> <p style="text-align: left">Fuel Pump Relay</p> <p style="text-align: left">Fuse Holder</p> <p style="text-align: left">Technical Manual / Booklet</p> <p style="text-align: left"></p> <p style="text-align: left"><strong>General:- </strong></p> <p style="text-align: left">Weight 500gm</p> <p style="text-align: left">Extruded Aluminum case</p> <p style="text-align: left">1 Year Warranty</p> <p style="text-align: left">16 Bit Motorola Processor</p> <p style="text-align: left">Surface Mount technology board</p> <p style="text-align: left">Supports up to 12cyl and 4 rotor engines</p> <p style="text-align: left">Max readable RPM 15950</p> <p style="text-align: left">Standard map sensor 20psi</p> <p style="text-align: left">(28 & 45psi available as an option)</p> <p style="text-align: left"></p> <p style="text-align: left"><strong>Fuel Delivery:-</strong></p> <p style="text-align: left">4 Injector Drivers capable of 4 amp peak hold.</p> <p style="text-align: left">True sequential operation on 4 cylinder and rotary applications</p> <p style="text-align: left">Run up to 4 high impedance injectors per driver</p> <p style="text-align: left">Tunable in MAP or TPS mode or combination of both.</p> <p style="text-align: left">Main Matrix table has 16x16 load sites </p> <p style="text-align: left">RPM tuning range currently every 500rpm to 9000rpm</p> <p style="text-align: left">Overall Mixture trim +-99%</p> <p style="text-align: left"><strong>Fuel Delivery Cont:-</strong></p> <p style="text-align: left">Auxiliary Input correction +-99%</p> <p style="text-align: left">Coolant temp correction</p> <p style="text-align: left">Air temp correction</p> <p style="text-align: left">Accelerator pump amount, sensitivity and Time</p> <p style="text-align: left">compensation</p> <p style="text-align: left">Cranking enrichment correction</p> <p style="text-align: left">After start enrichment correction</p> <p style="text-align: left">Cold Start accelerator pump correction</p> <p style="text-align: left">Hard cut RPM limiter</p> <p style="text-align: left">Soft cut RPM Limiter</p> <p style="text-align: left">Over boost Limiter</p> <p style="text-align: left">Sequential, Group fire and Staged/Group fire modes</p> <p style="text-align: left"></p> <p style="text-align: left"><strong>Ignition:-</strong></p> <p style="text-align: left">Includes X4 Ignitor Box </p> <p style="text-align: left">4 Ignition drivers</p> <p style="text-align: left">Ignition setup preconfigured for engine type.</p> <p style="text-align: left">Configurable for 1-4 cylinder direct fire or 1-8cyl wasted spark</p> <p style="text-align: left">Configurable for up to 4 rotor engines</p> <p style="text-align: left">16 Ignition RPM sites </p> <p style="text-align: left">16 Map corrections </p> <p style="text-align: left">16 water temp correction points</p> <p style="text-align: left">16 air temp correction points</p> <p style="text-align: left">Ignition advance/retard on accelerator pump</p> <p style="text-align: left">Ignition advance/retard on aux input trigger</p> <p style="text-align: left">Ignition Trim overall +-45deg</p> <p style="text-align: left">Ignition timing split adjustable on rotary applications</p> <p style="text-align: left">Aux inputs and outputs:-</p> <p style="text-align: left">Standard features include One 12V Aux input</p> <p style="text-align: left">One -ve switched Aux output triggered by RPM, Map, and water temp</p> <p style="text-align: left"></p> <p style="text-align: left"><strong>Diagnostics:-</strong></p> <p style="text-align: left">Red LED indicated Fault code triggered</p> <p style="text-align: left">Data Page indicates where fault lies</p> <p style="text-align: left">Operational errors:-. Over boost, RPM Limit, RPM Cut, MAX Duty, Water temp, Voltage, Shift Light</p> <p style="text-align: left">Self Test Mode runs all injectors and ignition and cycles aux outputs</p> <p style="text-align: left">Amber LED gives Visual of ignition input signal</p> <p style="text-align: left">Green LED gives visual of power on.</p> <p style="text-align: left">Programming/ Tuning:-</p> <p style="text-align: left">Using Laptop adapter and software</p> <p style="text-align: left">Using Handset or DASH unit</p> <p style="text-align: left"></p> <p style="text-align: left"><strong>Sensors:-</strong></p> <p style="text-align: left">Configured to suit application when ordered.</p> <p style="text-align: left">Data logging and map storage:-</p> <p style="text-align: left">Data Log to Memory (Laptop) </p> <p style="text-align: left">Data log viewable in text or Graph</p> <p style="text-align: left">Playback data log</p> <p style="text-align: left">Print data log</p> <p style="text-align: left">Save data log to disc</p> <p style="text-align: left">4 Maps savable to laptop adapter or handset</p> <p style="text-align: left"></p> <p style="text-align: left"></p> <p style="text-align: left"></p></blockquote><p></p>
[QUOTE="jinkl-, post: 735195, member: 10049"] [b]A[/b] [url="http://www.emergent.com.au/200sx/ecudata.html#A1"][color=#800080]Apexi PowerFC[/color][/url] [url="http://www.emergent.com.au/200sx/ecudata.html#A2"][color=#800080]Autronic SMC[/color][/url] [url="http://www.emergent.com.au/200sx/ecudata.html#A3"][color=#800080]Autronic SM2[/color][/url] [b]E[/b] [url="http://www.emergent.com.au/200sx/ecudata.html#E1"][color=#800080]EMS Dual Sport[/color][/url] [b]H[/b] [url="http://www.emergent.com.au/200sx/ecudata.html#H1"][color=#800080]Haltec E6K[/color][/url][url="http://www.emergent.com.au/200sx/ecudata.html#H2"][color=#800080]Haltech E6H/M[/color][/url][url="http://www.emergent.com.au/200sx/ecudata.html#H3"][color=#800080]Haltech E6S[/color][/url][url="http://www.emergent.com.au/200sx/ecudata.html#HA1"][color=#800080]Hawk EC21[/color][/url][b]L[/b][url="http://www.emergent.com.au/200sx/ecudata.html#L1"][color=#800080]Link Plug-In[/color][/url][url="http://www.emergent.com.au/200sx/ecudata.html#L2"][color=#800080]Link Wire-In[/color][/url] [b]M[/b]Microtech Digi[url="http://www.emergent.com.au/200sx/ecudata.html#M1"][color=#800080]MoTeC M4 Clubman[/color][/url] [url="http://www.emergent.com.au/200sx/ecudata.html#M2"][color=#800080]MoTeC M4 Pro[/color][/url] [url="http://www.emergent.com.au/200sx/ecudata.html#M3"][color=#800080]MoTeC M48 Clubman[/color][/url] [url="http://www.emergent.com.au/200sx/ecudata.html#M4"][color=#800080]MoTeC M48 Pro[/color][/url] [url="http://www.emergent.com.au/200sx/ecudata.html#M5"][color=#800080]MoTeC M800[/color][/url] [url="http://www.emergent.com.au/200sx/ecudata.html#M6"][color=#800080]Motec M8 Pro[/color][/url] [b]N[/b][url="http://www.emergent.com.au/200sx/ecudata.html#N1"][color=#800080]Nissan ECCS (JECS)[/color][/url] [b]W[/b][url="http://www.emergent.com.au/200sx/ecudata.html#W1"][color=#800080]Wolf 3D v3.0[/color][/url] [b][url="http://www.apexi.co.jp/"][color=#800080]Apexi[/color][/url] PowerFC[/b] CPUNEC 78P334 @ 16MHzMax Cylinders6Fuel Maps20Ignition Maps20Load Points per Map20Total Fuel Points400Total Ignition Points400Fuel Correction Maps or FactorsCoolant TempIgnition Correction Maps or FactorsCoolant TempInjector Outputs6Ignition Outputs6Auxiliary Inputs0Auxiliary Outputs0O2 SensorYes (OEM)Closed Loop OperationYesData LoggingNoBoost ControlYes (Optional)Traction/Launch ControlNoNitrous ManagementNoVTEC ControlNoAnti-LagNoFlat-ShiftUnknownPC ProgrammableNoHandset ProgrammableYes - Controller not included[b] Autronic SMC[/b] CPUIntel 16-bit @ 16MHzMax Cylinders16Fuel Maps32Ignition Maps32Load Points per Map16Total Fuel Points512Total Ignition Points512Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Throttle Pump, Injector TrimIgnition Correction Maps or FactorsCoolant Temp, Air Temp, AltitudeInjector Outputs8Ignition Outputs4Auxiliary Inputs1Auxiliary OutputsMax 5 (Depending on number of injectorrs)O2 SensorYes (Wideband)Closed Loop OperationYesData LoggingYesBoost ControlYesTraction/Launch ControlNoNitrous ManagementNoVTEC ControlIndirect (RPM/Load Operated output)Anti-LagYesFlat-ShiftYesPC ProgrammableYes - DOSHandset ProgrammableNo[b]Autronic SM2[/b] CPUIntel 16-bit @ 16MHzMax Cylinders16Fuel Maps32Ignition Maps32Load Points per Map16Total Fuel Points512Total Ignition Points512Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Throttle Pump, Injector TrimIgnition Correction Maps or FactorsCoolant Temp, Air Temp, AltitudeInjector Outputs8Ignition Outputs4Auxiliary Inputs3Auxiliary Outputs9O2 SensorYesClosed Loop OperationYesData LoggingYesBoost ControlYesTraction/Launch ControlYesNitrous ManagementYesVTEC ControlIndirect (RPM/Load Operated output)Anti-LagYesFlat-ShiftYesPC ProgrammableYes - DOSHandset ProgrammableNo[b][url="http://www.enginemanagementsystem.com/"][color=#0000ff]EMS[/color][/url] Dual Sport I[/b] CPUMotorola 16-bitMax Cylinders16Fuel Maps26Ignition Maps26Load Points per Map3 + 16 Curve ModifiersTotal Fuel Points78 (excluding curve modifiers)Total Ignition Points78 (excluding curve modifiers)Fuel Correction Maps or FactorsCoolant temp, Air temp, Full throttle, Closed throttle, Battery voltage, Throttle pump, Fuel trim, Curve modifier, Barometric pressure, Variable injection resolution, Sync/Async injection resolution, Prediction algorithmIgnition Correction Maps or FactorsCoolant temp, Barometric presureInjector Outputs8Ignition Outputs4Auxiliary Inputs1Auxiliary Outputs4O2 SensorOptional (Wideband)Closed Loop OperationNoData LoggingYes (To laptop)Boost ControlYesTraction/Launch ControlNoNitrous ManagementYesVTEC ControlYesAnti-LagYesFlat-ShiftNoPC ProgrammableYes - WindowsHandset ProgrammableYes - Included[b][url="http://www.haltech.com.au/"][color=#0000ff]Haltech[/color][/url] E6K[/b] CPUMotorola 68HC11K4 @ 16MHzMax Cylinders12Fuel Maps17 or 22Ignition Maps17 or 22Load Points per Map32Total Fuel Points544 or 704Total Ignition Points544 or 704Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Injector Phasing, Throttle Pump, Injector Trim, Barometric PressureIgnition Correction Maps or FactorsCoolant Temp, Air TempInjector Outputs8Ignition Outputs4Auxiliary Inputs2Auxiliary Outputs6O2 SensorYes (Wideband)Closed Loop OperationYesData LoggingYesBoost ControlYesTraction/Launch ControlYesNitrous ManagementYesVTEC ControlYesAnti-LagYesFlat-ShiftYesPC ProgrammableYes - DOSHandset ProgrammableNo[b][url="http://www.haltech.com.au/"][color=#0000ff]Haltech[/color][/url] E6H/E6M[/b] CPUMotorola 68HC11K4 @ 16MHzMax Cylinders12Fuel Maps17 or 22Ignition Maps17 or 22Load Points per Map32Total Fuel Points544 or 704Total Ignition Points544 or 704Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Injector Phasing, Throttle Pump, Injector Trim, Barometric PressureIgnition Correction Maps or FactorsCoolant Temp, Air TempInjector Outputs8Ignition Outputs4Auxiliary Inputs2Auxiliary Outputs2O2 SensorYes (Wideband)Closed Loop OperationYesData LoggingYesBoost ControlYesTraction/Launch ControlYesNitrous ManagementYesVTEC ControlYesAnti-LagYesFlat-ShiftYesPC ProgrammableYes - DOSHandset ProgrammableNo[b][url="http://www.haltech.com.au/"][color=#0000ff]Haltech[/color][/url] E6S[/b] CPUMotorola 68HC11E2 @ 8MHzMax Cylinders12Fuel Maps17 or 22Ignition Maps17 or 22Load Points per Map32Total Fuel Points544 or 704Total Ignition Points544 or 704Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Injector Phasing, Throttle Pump, Injector TrimIgnition Correction Maps or FactorsCoolant Temp, Air TempInjector Outputs4 or 8Ignition Outputs4Auxiliary Inputs2Auxiliary Outputs2O2 SensorYes (Wideband)Closed Loop OperationYesData LoggingYesBoost ControlYesTraction/Launch ControlYesNitrous ManagementYesVTEC ControlYesAnti-LagYesFlat-ShiftNoPC ProgrammableYes - DOSHandset ProgrammableNo[b][url="http://www.efihardware.com/"][color=#0000ff]Hawk[/color][/url] EC21[/b] CPUUnknown @8MHzMax Cylinders Fuel Maps128Ignition Maps128Load Points per Map16Total Fuel Points2048Total Ignition Points2048Fuel Correction Maps or FactorsAir Temp, Coolant TempIgnition Correction Maps or FactorsCoolant Temp, Air TempInjector Outputs2Ignition Outputs4Auxiliary Inputs0Auxiliary Outputs2O2 SensorYesClosed Loop OperationUnknown (probably yes)Data LoggingNoBoost ControlNoTraction/Launch ControlNoNitrous ManagementNoVTEC ControlNoAnti-LagNoFlat-ShiftNoPC ProgrammableYes - DOSHandset ProgrammableNo[b]Link Plug-In[/b] CPUUnknownMax Cylinders6Fuel Maps8Ignition Maps8Load Points per Map16Total Fuel Points128Total Ignition Points128Fuel Correction Maps or FactorsCoolant TempIgnition Correction Maps or FactorsCoolant TempInjector Outputs6Ignition Outputs4Auxiliary Inputs0Auxiliary Outputs0O2 SensorYes (OEM)Closed Loop OperationYesData LoggingOptionalBoost ControlYesTraction/Launch ControlNoNitrous ManagementNoVTEC ControlNoAnti-LagNoFlat-ShiftNoPC ProgrammableMinimal - Download Maps via comms programHandset ProgrammableYes - Optional[b]Link Wire-In[/b] CPUUnknownMax Cylinders12Fuel Maps8Ignition Maps8Load Points per Map16Total Fuel Points128Total Ignition Points128Fuel Correction Maps or FactorsCoolant TempIgnition Correction Maps or FactorsCoolant TempInjector Outputs8Ignition Outputs4Auxiliary Inputs2Auxiliary Outputs4O2 SensorYes (Wideband)Closed Loop OperationYesData LoggingOptionalBoost ControlYesTraction/Launch ControlNoNitrous ManagementNoVTEC ControlYesAnti-LagNoFlat-ShiftNoPC ProgrammableMinimal - Download Maps via comms programHandset ProgrammableYes - Optional[b][url="http://www.motec.com.au/"][color=#0000ff]MoTeC[/color][/url] M4 Clubman[/b] CPUMotorola 32-bit @ 33MHzMax Cylinders12Fuel Maps40Ignition Maps40Load Points per Map21Total Fuel Points840Total Ignition Points840Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Throttle Pump, Injector TrimIgnition Correction Maps or FactorsCoolant Temp, Air TempInjector Outputs4Ignition Outputs4Auxiliary Inputs2Auxiliary OutputsMax 3 (Depending on Number of Cylinders)O2 SensorYes (Narrow Band)Closed Loop OperationYesData LoggingOptionalBoost ControlYesTraction/Launch ControlOptionalNitrous ManagementYesVTEC ControlIndirect (RPM Operated output)Anti-LagNoFlat-ShiftNoPC ProgrammableYes - DOSHandset ProgrammableNo[b][url="http://www.motec.com.au/"][color=#0000ff]MoTeC[/color][/url] M4 Pro[/b] CPUMotorola 32-bit @ 33MHzMax Cylinders12Fuel Maps40Ignition Maps40Load Points per Map21Total Fuel Points840Total Ignition Points840Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Throttle Pump, Injector TrimIgnition Correction Maps or FactorsCoolant Temp, Air TempInjector Outputs4Ignition Outputs4Auxiliary Inputs2Auxiliary OutputsMax 3 (Depending on Number of Cylinders)O2 SensorYes (Wideband)Closed Loop OperationYesData LoggingYesBoost ControlYesTraction/Launch ControlOptionalNitrous ManagementYesVTEC ControlIndirect (RPM Operated output)Anti-LagYesFlat-ShiftYesPC ProgrammableYes - DOSHandset ProgrammableNo[b][url="http://www.motec.com.au/"][color=#0000ff]MoTeC[/color][/url] M48 Clubman[/b] CPUMotorola 32-bit @ 33MHzMax Cylinders12Fuel Maps40Ignition Maps40Load Points per Map21Total Fuel Points840Total Ignition Points840Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Throttle Pump, Injector TrimIgnition Correction Maps or FactorsCoolant Temp, Air TempInjector Outputs8Ignition Outputs2Auxiliary Inputs2Auxiliary OutputsMax 3 (Depending on Number of Cylinders)O2 SensorYes (Narrow Band)Closed Loop OperationYesData LoggingOptionalBoost ControlYesTraction/Launch ControlOptionalNitrous ManagementYesVTEC ControlIndirect (RPM Operated output)Anti-LagNoFlat-ShiftNoPC ProgrammableYes - DOSHandset ProgrammableNo[b][url="http://www.motec.com.au/"][color=#0000ff]MoTeC[/color][/url] M48 Pro[/b] CPUMotorola 32-bit @ 33MHzMax Cylinders12Fuel Maps40Ignition Maps40Load Points per Map21Total Fuel Points840Total Ignition Points840Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Throttle Pump, Injector TrimIgnition Correction Maps or FactorsCoolant Temp, Air TempInjector Outputs8Ignition Outputs2Auxiliary Inputs2Auxiliary OutputsMax 3 (Depending on Number of Cylinders)O2 SensorYes (Wideband)Closed Loop OperationYesData LoggingYesBoost ControlYesTraction/Launch ControlOptionalNitrous ManagementYesVTEC ControlIndirect (RPM Operated output)Anti-LagYesFlat-ShiftYesPC ProgrammableYes - DOSHandset ProgrammableNo[b][url="http://www.motec.com.au/"][color=#0000ff]MoTeC[/color][/url] M800[/b] CPUMotorola 32-bit @ 66MHz (not confirmed)Max Cylinders12Fuel Maps40Ignition Maps40Load Points per Map21Total Fuel Points840Total Ignition Points840Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Throttle Pump, Injector TrimIgnition Correction Maps or FactorsCoolant Temp, Air TempInjector Outputs8 (Unused outputs can be used as general purpose)Ignition Outputs6 (Unused outputs can be used as general purpose)Auxiliary Inputs4Auxiliary Outputs8Temperature Inputs6Voltage Inputs8O2 SensorYes (Dual Wideband)Closed Loop OperationYesData LoggingYesBoost ControlYesTraction/Launch ControlYesNitrous ManagementYesVTEC ControlIndirect (RPM Operated output)Anti-LagYesFlat-ShiftYesPC ProgrammableYes - DOSHandset ProgrammableNo[b][url="http://www.motec.com.au/"][color=#0000ff]MoTeC[/color][/url] M8 Pro[/b] M8 Has been made obsolete by the M800, but it's still a good reference. CPUMotorola 32-bit @ 33MHzMax Cylinders12Fuel Maps40Ignition Maps40Load Points per Map21Total Fuel Points840Total Ignition Points840Fuel Correction Maps or FactorsCoolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Throttle Pump, Injector TrimIgnition Correction Maps or FactorsCoolant Temp, Air TempInjector Outputs4Ignition Outputs4Auxiliary Inputs2Auxiliary OutputsMax 3 (Depending on Number of Cylinders)O2 SensorYes (Wideband)Closed Loop OperationYesData LoggingYesBoost ControlYesTraction/Launch ControlYesNitrous ManagementYesVTEC ControlIndirect (RPM Operated output)Anti-LagYesFlat-ShiftYesPC ProgrammableYes - DOSHandset ProgrammableNo[b]Nissan ECCS (JECS)[/b] CPUMotorola 16-bitMax Cylinders6Fuel Maps16 Low-Octane, 16 High-OctaneIgnition Maps16 Low-Octane, 16 High-OctaneLoad Points per Map16Total Fuel Points256 Low-Octane, 256 High-OctaneTotal Ignition Points256 Low-Octane, 256 High-OctaneFuel Correction Maps or FactorsWater Temp, Throttle Off, AccelerationIgnition Correction Maps or FactorsWater TempInjector Outputs6Ignition Outputs6Auxiliary Inputs0Auxiliary Outputs0O2 SensorYes (Narrow band)Closed Loop OperationYesData LoggingLimited (Fault Codes and Self-Learn)Boost ControlYesTraction/Launch ControlNoNitrous ManagementNoVTEC ControlNICSAnti-LagNoFlat-ShiftNoPC ProgrammableNoHandset ProgrammableLimited - Dealer/OEM CONSULT tool[b][url="http://www.wolfems.com.au/"][color=#0000ff]Wolf[/color][/url] 3D v3.0[/b] CPUUnknownMax Cylinders12Fuel Maps16Ignition Maps16Load Points per Map8Total Fuel Points128Total Ignition Points128Fuel Correction Maps or FactorsCoolant Temp, AccelerationIgnition Correction Maps or FactorsCoolant Temp, AccelerationInjector Outputs4Ignition Outputs4Auxiliary InputsUnknownAuxiliary Outputs2O2 SensorYes (Narrow Band)Closed Loop OperationNoData LoggingOptionalBoost ControlYesTraction/Launch ControlNoNitrous ManagementNoVTEC ControlNoAnti-LagNoFlat-ShiftNoPC ProgrammableYes (Windows)Handset ProgrammableYes - Included [left] Microtech : Microtech LT10S (Replaces LTX8) [841]$1,425.00nzhttp://www.japaneseperformance.co.nz/images/pixel_trans.gif[url="javascript:popupWindow('http://www.japaneseperformance.co.nz/popup_image.php?pID=3926&osCsid=257fea11e0d46eef05ddf8d9dbe3695b')"]http://www.japaneseperformance.co.nz/images/LT10Ssml.jpg [color=#0000ff]Click to enlarge[/color][/url] [url="http://www.japaneseperformance.co.nz/images/LT10Ssml.jpg?osCsid=257fea11e0d46eef05ddf8d9dbe3695b"][img]images/LT10Ssml.jpg[/img] Click to enlarge[/url][b]Specification sheet:- Kit Contents:-[/b] ECU Flying Lead Wiring Loom (labeled) Vacuum Hose Fuel Pump Relay Fuse Holder Technical Manual / Booklet [b]General:- [/b] Weight 500gm Extruded Aluminum case 1 Year Warranty 16 Bit Motorola Processor Surface Mount technology board Supports up to 12cyl and 4 rotor engines Max readable RPM 15950 Standard map sensor 20psi (28 & 45psi available as an option) [b]Fuel Delivery:-[/b] 4 Injector Drivers capable of 4 amp peak hold. True sequential operation on 4 cylinder and rotary applications Run up to 4 high impedance injectors per driver Tunable in MAP or TPS mode or combination of both. Main Matrix table has 16x16 load sites RPM tuning range currently every 500rpm to 9000rpm Overall Mixture trim +-99% [b]Fuel Delivery Cont:-[/b] Auxiliary Input correction +-99% Coolant temp correction Air temp correction Accelerator pump amount, sensitivity and Time compensation Cranking enrichment correction After start enrichment correction Cold Start accelerator pump correction Hard cut RPM limiter Soft cut RPM Limiter Over boost Limiter Sequential, Group fire and Staged/Group fire modes [b]Ignition:-[/b] Includes X4 Ignitor Box 4 Ignition drivers Ignition setup preconfigured for engine type. Configurable for 1-4 cylinder direct fire or 1-8cyl wasted spark Configurable for up to 4 rotor engines 16 Ignition RPM sites 16 Map corrections 16 water temp correction points 16 air temp correction points Ignition advance/retard on accelerator pump Ignition advance/retard on aux input trigger Ignition Trim overall +-45deg Ignition timing split adjustable on rotary applications Aux inputs and outputs:- Standard features include One 12V Aux input One -ve switched Aux output triggered by RPM, Map, and water temp [b]Diagnostics:-[/b] Red LED indicated Fault code triggered Data Page indicates where fault lies Operational errors:-. Over boost, RPM Limit, RPM Cut, MAX Duty, Water temp, Voltage, Shift Light Self Test Mode runs all injectors and ignition and cycles aux outputs Amber LED gives Visual of ignition input signal Green LED gives visual of power on. Programming/ Tuning:- Using Laptop adapter and software Using Handset or DASH unit [b]Sensors:-[/b] Configured to suit application when ordered. Data logging and map storage:- Data Log to Memory (Laptop) Data log viewable in text or Graph Playback data log Print data log Save data log to disc 4 Maps savable to laptop adapter or handset [/left] [/QUOTE]
david tao
About Skyline R34
Hello greeting to sifu-sifu, I plan to get a R34, but I think I need more info about it, like the common problems of the car, the engine stuffs and so on.
So any Skyline owners here and any Skyline pro here can...
Ferrari 599 GTO the greatest ever made? Find out here
https://www.zerotohundred.com/wp-content/uploads/2010/06/599-GTO.jpg
The Ferrari 599 GTO marks the revival of the GTO brand first seen in the legendary 250 GTO of the early 60's and later in the 288 GTO of 1984...
R34 GTR V Spec + Garrett GT42R = 727hp@Wheel
Shot these a few days ago..
http://www.autojunctions.com/images/stories/prow/09/r34gar/cover.jpg
It's really a freaking crazy ass-ed car! Specs are listed at my site.. but here are some pics
Exterior...
Main Forums
Car Talk
