Main Forums
General Talk
EFI car tuning
<blockquote data-quote="zan" data-source="post: 421782" data-attributes="member: 9632"><p>modern engines with fuel injection are very intelligent indeed with their computerised ECU. the advantage of this is the engine does it tuning on its own at all time whether its cold or warm.</p><p></p><p>what normally people mean by tuning is simply on the maintenance side for air filter and spark plugs (clean or replaced for both items). EFI oso really need clean fuel supply, so fuel filter replacement must be punctual to avoid unnecessary stalling or jerking. other than that, EFI does everything on its own except maybe for engine idle level which u can adjust low as per specification or higher.</p><p></p><p>u open one workshop, then tell ur customer that ur car no need tuning one. how do u survive? so, must tell kena tuning one...</p><p></p><p>p/s tuning used to be time assuming for old cars with air filter and spark plug to start. then it wud be the contact point gap adjustment, then the distributor rotor cleaning, check timing then check need to tune the carburettor. a good tune will result good combustion resulting water vapour at ur exhaust tail pipe. that was the eighties...</p></blockquote><p></p>
[QUOTE="zan, post: 421782, member: 9632"] modern engines with fuel injection are very intelligent indeed with their computerised ECU. the advantage of this is the engine does it tuning on its own at all time whether its cold or warm. what normally people mean by tuning is simply on the maintenance side for air filter and spark plugs (clean or replaced for both items). EFI oso really need clean fuel supply, so fuel filter replacement must be punctual to avoid unnecessary stalling or jerking. other than that, EFI does everything on its own except maybe for engine idle level which u can adjust low as per specification or higher. u open one workshop, then tell ur customer that ur car no need tuning one. how do u survive? so, must tell kena tuning one... p/s tuning used to be time assuming for old cars with air filter and spark plug to start. then it wud be the contact point gap adjustment, then the distributor rotor cleaning, check timing then check need to tune the carburettor. a good tune will result good combustion resulting water vapour at ur exhaust tail pipe. that was the eighties... [/QUOTE]
GS300 brakes
Hi guys,its me again..
I am looking for a used GS300 brakes,complete set callipers and rotors.
Most of the kedai potong i went to does not carry Lexus parts,im sure theres a few chop shop that brings in Lexus...
Touge
How about this trip --->(Kuala kelawang-genting peres-Cheras)?does anyone here has try those route?
Question: R33-GTR
Got a picture from a friend. Does any sifu's here knows what module is this in the red box?
This got me puzzled and I can't read Japanese on Nissan FAST!
http://i31.photobucket.com/albums/c374/eddie_yong/g-s.jpg
Main Forums
General Talk
EFI car tuning
