Main Forums
Car Talk
effect on overheated engine?
<blockquote data-quote="shazmi3" data-source="post: 2274462" data-attributes="member: 10475"><p>have u service the engine oil? if the engine vibrate differently it cause of ur timing not at the proper level..wats the rpm reading when idling?</p><p></p><p>i suggest u bring ur car to check the engine..but for me, i think theres no problem with ur engine...</p></blockquote><p></p>
[QUOTE="shazmi3, post: 2274462, member: 10475"] have u service the engine oil? if the engine vibrate differently it cause of ur timing not at the proper level..wats the rpm reading when idling? i suggest u bring ur car to check the engine..but for me, i think theres no problem with ur engine... [/QUOTE]
R35 Used Titanium Exhaust
Citra Engine
How make engine power & safe fuel
Custom Intake Matters
Hi all Guru's and Sifu's
i would like your expert opinions regarding custom intakes ... btw i'm talking about Drag Specs
1. Some say those trumpets connected to the runners are of no use because during high...
Load Dyno Vs Inertia Dyno
This discussion revolves around chassis dynamometer's and is intended to be informative and thought provoking. There are two types of chassis dynamometers on the market, inertia and loading. An inertia dynamometer...
sn964444
Main Forums
Car Talk
