Main Forums
Car Talk
Forced Induction & Engine Management
ECU Ignition Problem
<blockquote data-quote="Kareem77" data-source="post: 1063411508" data-attributes="member: 110514"><p>Bless up. I have a problem with my 1998 Daihatsu Move L601. I changed my car from Automatic to Gearbox, after that convertion the car cranks but no spark from the ingition coil. </p><p></p><p>I had ran a series test on the distributor pickup coil (249ohms, .247ACVolts), test the ignition coil(primary circuit(.9ohms) Secondary Circuit(13kOhms))and dont no how test to the ECU Transistor.</p><p></p><p>I carried the ECU to an electrical technician and he told me a IC was bad, so i had a identical ECU and replace the IC.</p><p></p><p>The car also is displaying a diagnostic code (51(Switch Signal)) found out the TPS sensor is not working.</p><p></p><p>Could someone tell me what i could do to get the car to start, and if i could get a ignition moulde to go around the ECU?</p><p></p><p>Thank you.</p></blockquote><p></p>
[QUOTE="Kareem77, post: 1063411508, member: 110514"] Bless up. I have a problem with my 1998 Daihatsu Move L601. I changed my car from Automatic to Gearbox, after that convertion the car cranks but no spark from the ingition coil. I had ran a series test on the distributor pickup coil (249ohms, .247ACVolts), test the ignition coil(primary circuit(.9ohms) Secondary Circuit(13kOhms))and dont no how test to the ECU Transistor. I carried the ECU to an electrical technician and he told me a IC was bad, so i had a identical ECU and replace the IC. The car also is displaying a diagnostic code (51(Switch Signal)) found out the TPS sensor is not working. Could someone tell me what i could do to get the car to start, and if i could get a ignition moulde to go around the ECU? Thank you. [/QUOTE]
R35 Used Titanium Exhaust
Hankook V12 Evo2 finally here
My friend saw these in tyre shop (Acanta), finally here, really long wait.....:driver...
Mugen CR-Z in the flesh
https://www.zerotohundred.com/wp-content/uploads/2011/05/crz1-600x399.jpg
Up to this point, all we’ve had to go on are renderings and speculated details regarding the spiced up version of Honda’s CR-Z, the Mugen...
Xtreme Evo engine Build 1000hp
Last a week meeting with profesional engine build and Engineering Factory from Australia agree to SPONSOR set of Dog Gear for Anybody build the Evo engine under 3rd GearPerformance Racing with 1000whp for Xtreme Drag...
sn964444
Main Forums
Car Talk
