Main Forums
Car Talk
Forced Induction & Engine Management
e manage acc
<blockquote data-quote="speed2horizon" data-source="post: 4072453" data-attributes="member: 30831"><p>U cannot be seeing too many things in 1 time when u drive and ur tuner tune the car. Ur rpm, ur boost, ur wideband. So, the engine behavior history will be recorder in the e-manage temporrarily.</p><p></p><p>So concentrate on the wideband and rpm. then when u refer back on the graph in the laptop, u can see the boost input signal along ur rev....</p><p></p><p>When did the boost kicks in and things like that...</p><p></p><p>U can even tune the car without the MAP sensor...</p></blockquote><p></p>
[QUOTE="speed2horizon, post: 4072453, member: 30831"] U cannot be seeing too many things in 1 time when u drive and ur tuner tune the car. Ur rpm, ur boost, ur wideband. So, the engine behavior history will be recorder in the e-manage temporrarily. So concentrate on the wideband and rpm. then when u refer back on the graph in the laptop, u can see the boost input signal along ur rev.... When did the boost kicks in and things like that... U can even tune the car without the MAP sensor... [/QUOTE]
Random Shot: Verde Ithaca R35 Godzilla
From far, when I saw this green reflected on the ceiling, I knew it was something special.
Verde Ithaca
. I was familiar with...
greedy T88-34D for sale....
http://i31.photobucket.com/albums/c384/jacbnr34/T88-1.jpg
http://i31.photobucket.com/albums/c384/jacbnr34/T88-2.jpg
turbine spec: T88-34d 22cm at the back. it used only half a year about 6000km.... still in very...
Replace speedometer cable
any sifu out there knows how to replace/remove the speedometer cable for satria?
mine making a lot of noise when cruising at 110km/h.
i know how to remove the front panel but never try removing the meter console...
Main Forums
Car Talk
e manage acc
