Main Forums
Car Talk
Car Modification
Downpipe leaking
<blockquote data-quote="Jay5" data-source="post: 581830" data-attributes="member: 2810"><p>heyy jase, wassup with the piping mod...your current modded one not powerful enough? :D</p><p></p><p>dont worry its fine to drive around for 20 mins...wind down your windows if you are afraid you will suffocate from exhaust gases escaping into your car....:)</p></blockquote><p></p>
[QUOTE="Jay5, post: 581830, member: 2810"] heyy jase, wassup with the piping mod...your current modded one not powerful enough? :D dont worry its fine to drive around for 20 mins...wind down your windows if you are afraid you will suffocate from exhaust gases escaping into your car....:) [/QUOTE]
R35 Used Titanium Exhaust
Lamborghini releases teaser image of upcoming Murcielago replacement model
https://www.zerotohundred.com/wp-content/uploads/2010/06/lambo-teaser.jpg
First introduced in 2001, the Lamborghini Murcielago has spawned a number of models including the Reventon and the ultra fast Super Veloce...
Evo7,8 Japan and Evo7,8 USA???
Hi guys......
Is japan spec evo and us spec evo same???
are they using same oil???
can USa oil like REDLINE use in japan spec EVO???
example:
REDLINE MTL+MT9O use in EVO7,8 japan spec gearbox???
REDLINE 75w90 GL5...
anyone done this mod before?
i sourced out this from japanese webpage.the translation for the mod would be "full time secondary duct opening".from what i understand from reading it is the merit would be the torque feel from 2000-4000 rpm range...
Main Forums
Car Talk
Car Modification
Downpipe leaking
