Main Forums
Car Talk
Car Modification
does safc cure & solve idling problem?
<blockquote data-quote="jinkl-" data-source="post: 873844" data-attributes="member: 10049"><p>r u on MAF ?</p><p>r u recirculating ur BOV ?</p><p>r u using standard BOV ?</p><p>if aftermarket BOV , is it tight enough to prevent leak ?</p><p>is ur ISC ok ?</p><p>ur throthle body clean ?</p><p>ur vacuum hoses no bocor ?</p><p>check ur breather ok or not</p></blockquote><p></p>
[QUOTE="jinkl-, post: 873844, member: 10049"] r u on MAF ? r u recirculating ur BOV ? r u using standard BOV ? if aftermarket BOV , is it tight enough to prevent leak ? is ur ISC ok ? ur throthle body clean ? ur vacuum hoses no bocor ? check ur breather ok or not [/QUOTE]
Advan GT Beyond 19 Civic Type R FK8 FL5 Rim Wheel
TE37 Saga S Plus 18 Civic Type R FL5 FK8
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
Litchfield GTR R35 Road Suspension Kit Absorber
Another 4.0 GT3 RS arrives - A black one this time!
Re: Random Exotics Pics 2
This is the second GT3 RS 4.0 to be sighted in KL. One of the 2 of 5 units...
Blitz Access ECU
I just bought my FD3S about a month ago. It comes with a Blitz Access Ecu, the same as in the blitz/scorch drag rx7. I heard that the ecu is chipped (remapped?) in japan prior to ordering. U need to inform the...
looking for stock mrs rims
pls call me at 0167471728.. thx
Main Forums
Car Talk
Car Modification
