Main Forums
Interests
Do-It-Yourself Garage
DIY Session : Car Battery Relocation
<blockquote data-quote="cyclonite" data-source="post: 1888" data-attributes="member: 787"><p>It will surely be written on the battery what chemical it's using inside wan ler... like example 'Calium' or something like that. You gotta do some research online to learn how each technology works and then decide based on it.</p><p></p><p>If you relocate battery you can still use grounding wire but you have to pull one of the grounding wire all the way to the back seat and connect it to the negative(-) terminal lor.</p></blockquote><p></p>
[QUOTE="cyclonite, post: 1888, member: 787"] It will surely be written on the battery what chemical it's using inside wan ler... like example 'Calium' or something like that. You gotta do some research online to learn how each technology works and then decide based on it. If you relocate battery you can still use grounding wire but you have to pull one of the grounding wire all the way to the back seat and connect it to the negative(-) terminal lor. [/QUOTE]
R35 Used Titanium Exhaust
DIY Install soundproof
Hi,
just finished install soundproof to my ride.
tools needed : Pen-knife, ruler(metal), clean cloth, 10mm,12mm spanar..etc, screw driver
Soundproof material : Sikadamp-630 1box 18" x 32" + sikadamp -630 (800mm x...
help:got a problem about viechle setting on E-manage
i got a problem when i was doing viechle setting for a Mazda3. the problem is Mazda3 2.0L engine is not inclued in the viechle list on e-manage ultimate. so what can i do about that? using the universal mode? but...
Vortex Generators (Are they for real?)
For those who thinks VG's is just another piece of cosmetic items..
Here you go.
http://www.mitsubishi-motors.com/corporate/about_us/technology/review/e/pdf/2004/16E_03.pdf
Main Forums
Interests
