Main Forums
Interests
Do-It-Yourself Garage
DIY Power Windows
<blockquote data-quote="differ" data-source="post: 772565" data-attributes="member: 399"><p>not much solutions to the problems as the proton windows are a very simple mechanism which comes in 2 parts - the cable assembly/rack/regulator & the motor itself.</p><p></p><p>mivecmerah: what problems do you have? describe a bit ler bro, if not how to help.... -_-</p><p></p><p>jaywat: when you say loosy, does it mean that the glass can tilt forward/back. if so, it could be that your support for the glass in the regulator is loose already. not sure about iswara, so you will need to remove the rack and see if you can tighten it back. else, just change the regulator, which can cost upwards of rm80.</p></blockquote><p></p>
[QUOTE="differ, post: 772565, member: 399"] not much solutions to the problems as the proton windows are a very simple mechanism which comes in 2 parts - the cable assembly/rack/regulator & the motor itself. mivecmerah: what problems do you have? describe a bit ler bro, if not how to help.... -_- jaywat: when you say loosy, does it mean that the glass can tilt forward/back. if so, it could be that your support for the glass in the regulator is loose already. not sure about iswara, so you will need to remove the rack and see if you can tighten it back. else, just change the regulator, which can cost upwards of rm80. [/QUOTE]
Subaru’s record run of the Isle of Man TT w/video
https://www.zerotohundred.com/wp-content/uploads/2011/06/sti-600x400.jpg
Remember Subaru’s record attempt at the Isle of Man TT that saw driver Mark Higgins make the save of his life as the Impreza WRX STI made a...
Supercharger from Taiwan
Check out this website Weisake Industrial Co. Ltd
http://www.ref.com.tw/english/product/product-01-2.asp
They got supercharger kit for 4G93P ( satria GTi )...
RX 8 CF Bonnet
One Piece of CF ORiginal Style Bonnet for sales...
Please email to
[email protected]
Main Forums
Interests
DIY Power Windows
