Car Brands
Car Manufacturers
Toyota
Distributor for 4AGE 16V MAP
<blockquote data-quote="TRD16v" data-source="post: 1700960" data-attributes="member: 2009"><p>Ray,</p><p>wat kinda problem ur engine facing now?? wen u change timing belt got change tensioner bearing, oil seal and set the timing properly or not using timing gun? must make sure ur mech does all dis la.. den onli ur 16v is power mah.. ehehehehehe!</p><p></p><p></p><p></p><p></p><p></p><p></p><p>Regards,</p><p>Mike</p></blockquote><p></p>
[QUOTE="TRD16v, post: 1700960, member: 2009"] Ray, wat kinda problem ur engine facing now?? wen u change timing belt got change tensioner bearing, oil seal and set the timing properly or not using timing gun? must make sure ur mech does all dis la.. den onli ur 16v is power mah.. ehehehehehe! Regards, Mike [/QUOTE]
B16a vafc 1 need help.....
HELO O2100 MEMBER & OTAI....
I NEED SOME ADVICE & SUGGESTIONS
I JUST BOUGHT THIS CAR QUITE RECENTLY, DAYS AGO..... THE CAR GOT:
HARDWARE:
B16A BLOCK WITH B16B PISTON (NEW... STILL IN RUNNING...
BCNR33 GT-R for SALE :(
after much nagging by my wife since the day i bought this Skyline. Finally, i cant stand it anymore! i have to let go either my wife or the car. so cant be wife, so be the car......
details:-
BCNR33 GT-R...
er34 ratios
Hi gd am everyone.Anyone here knws what gear ratio and final drive for er34 25det neo automatic transmision?tq
Car Brands
Car Manufacturers
Toyota
