Main Forums
Car Talk
Car Detailing Forums
Difference between polishing and waxing
<blockquote data-quote="Exquisite Auto" data-source="post: 1064166061" data-attributes="member: 138031"><p>Junbecks has explained it rather well,we operate a paint shop and provide a variety of polishing services.Simply put,there are 3 fifferent types of polishing.</p><p></p><p>1-Polishing that's very fine and only affects the upper layer of lacquer.It provides a lovely shine but if the paint is distorted or has deep swirls it has little or no effect at all.This technique is commonly used by car wash joints.</p><p></p><p>2-Polishing that requires the use of proper polishing compound,it's the same compound thats used after cars are sprayed to remove any impurities during the process of spraying the 2nd coat of lacquer.This way any swirls/surface scratches/paint coming off due to rubbing against other cars(dependent on how severe the damage is) can be removed.It usually causes some distortion to the paint and requires machine polishing combined with a compound.</p><p></p><p>3-Polishing that requires wet sanding.This technique is used on cars that have surface stone chips/deep swirls and so forth.We usually wet sand using very fine sandpaper and follow through with a proper compound polish so as to restore the damaged section.</p><p></p><p>These for me would be the three types of polishing so when people tell me they've done a '2layer' polish at a car wash,i'm honestly clueless on what it means.Even if the car wash is applying 2 layers of polish,no compound is involved implying that one layer of gloss finish polish has been applied to another when even the first layer has not properly eaten into the paint(or lacquer for that matter) for it simply hasn't been designed to.</p></blockquote><p></p>
[QUOTE="Exquisite Auto, post: 1064166061, member: 138031"] Junbecks has explained it rather well,we operate a paint shop and provide a variety of polishing services.Simply put,there are 3 fifferent types of polishing. 1-Polishing that's very fine and only affects the upper layer of lacquer.It provides a lovely shine but if the paint is distorted or has deep swirls it has little or no effect at all.This technique is commonly used by car wash joints. 2-Polishing that requires the use of proper polishing compound,it's the same compound thats used after cars are sprayed to remove any impurities during the process of spraying the 2nd coat of lacquer.This way any swirls/surface scratches/paint coming off due to rubbing against other cars(dependent on how severe the damage is) can be removed.It usually causes some distortion to the paint and requires machine polishing combined with a compound. 3-Polishing that requires wet sanding.This technique is used on cars that have surface stone chips/deep swirls and so forth.We usually wet sand using very fine sandpaper and follow through with a proper compound polish so as to restore the damaged section. These for me would be the three types of polishing so when people tell me they've done a '2layer' polish at a car wash,i'm honestly clueless on what it means.Even if the car wash is applying 2 layers of polish,no compound is involved implying that one layer of gloss finish polish has been applied to another when even the first layer has not properly eaten into the paint(or lacquer for that matter) for it simply hasn't been designed to. [/QUOTE]
david tao
Evo workshop manaul & Tech info.
Ppl,
Check this out..... most info there are FOC... all u need is some hardisk space & Unifi...
Evo/Mit car workshop manual (evo 6 to 10):
Mitsubishi...
S13 parts for sale
Hi all,
I have upgraded my car, so I got these things lying around my workshop and house, thought you might wanna have a look at these:
01. Leather Steering Wheel (Taken out from a skyline halfcut)...
Diy : Undercarriage Lights
DIY : UnderCarriage Lights
These Step by step Pictures and detailed diagrams are courtesy of Xarrax from TBS.
Lot's of people asked this question before on DIY UnderCarriage Lights. Last time, I do not...
NoX
Main Forums
Car Talk
