http://i234.photobucket.com/albums/ee122/p_zi80/dcarbo.jpg
HAVE YOU EVER FELT THAT YOUR ENGINE IS SO HEAVY AND EXPERIENCE LOW POWER AS WELL AS HIGH FUEL CONSUMPTION?
THAT INDICATES THAT YOUR ENGINE IS FULL OF CARBON AND THE TIME HAS COME TO CLEAN UP THE WHOLE ENGINE TO RESTORE THE ENGINE TO AS NEW CONDITION.
THIS CAN BE DONE BY HAVING YOUR CAR ENGINE TOP OVERHAULED. BUT THIS MAY COST YOU THOUSANDS OF RM !
THIS IS THE NEW, LOW COST METHOD TO 'REPLACE' TOP OVERHAUL.
INTRODUCING....
D'CARBO - The New Technology and Cheapest Decarbonizer In The Malaysian Market. Personally I cannot find any decarbonizer sold online in other countries like USA, UK, European Countries, Japan, etc. Even the biggest online shop in the world like on ebay.com, ebay.co.uk, ebay.co.jp, ebay.com.au, etc, you will not find this kind of decarbonizer being sold. But there are several decarbonizer machines sold online for around USD3,000 to USD5000.
D'CARBO helps to restore the engine's performance up to the optimum level and reduce the fuel comsumption
D'Carbo has two certificates:
1. SIRIM QAS INTERNATIONAL REF NUM: 2006KL0920
2. TESTED BY SPEEDWORKS LABORATORY
Suitable for all vehicles (new/old, petrol/diesel, carburetor/fuel injectors) – turbo or normal cars, vans, lorries, buses, trucks, MPV, motorboats, etc. Works for both new and olds cars, which has mileage more than 20,000km.
- ADVANTAGES & BENEFITS
1. Clean up carbon in the combustion chamber, valves, spark plugs, piston, cylinders and intake manifold.
2. Like having top overhaul. But top overhaul may cost you thousands of dollars, depends on type of cars. This D'Carbo cleans your engine parts, you may not need top overhaul anymore.
3. Old engines felt like new. Feel your engine lighter and faster.
4. To reduce fuel consumption. Less carbon, lighter engine means less fuel consumption
5. Boost performance and horsepower for higher speed and acceleration whether on flat horizontal or slope level.
6. Smoother running engine by promoting a more complete combustion (reduce noise and vibration).
7. Easy and improve engine startup especially in the morning.
8. Extends engine life and cleans your engine by cleaning existing Carbon/Varnish Deposits.
9. Shield, extend and lengthen the life span of silencers, valves, cylinders, converters and spark plugs – save your money on the servicing costs!
10. Diminish dangerous, hurtful and polluted exhaust emissions (black haze, smock and poisonous gas emission).
11. Reduce engine temperature and sound
12. Cleaning process in less than 15 minutes with no tools needed!
13. Will not affect vehicle warranty - no cutting, no modification to the engine.
- How many bottles do I need to use?
For petrol:
2000cc and below – 1 bottle
2000cc and above – 2 bottles
More than 4 cylinders – 2 bottles
For diesel: 2 bottles
For best results, use every 10,000km to 20,000km.
- HOW IT WORKS
All vehicles after running for several kilometers, will experience carbon build up in the fuel line, combustion chamber, valves, piston, cylinders, etc. Now, introducing D’Carbo (a technology from combination of several countries including Germany), acting as a very effective carbon cleaner. Cleaning the carbon can help to optimise the performance of an engine so that the engine will be like new condition. This latest technology is called Preventive Maintenance Technology (PMT).
Fuel combustion is NEVER complete for all vehicles. That’s why we can smell petrol and see black smoke from our exhaust pipes. During cleaning process, you will see the carbon build up is cleansed and thrown away through the exhaust tip as smoke. That’s why you will see lots of smoke coming out from the exhaust tip during the cleaning process. After cleaning the carbon using D’Carbo, you will find some water dropping from the exhaust tip, which means the combustion is now complete. There some chemical formula that shows if H2O (water) is produced, the combustion is complete.
1 bottle for RM 45
2 - 9 bottles for RM 40 per bottle
10 bottles for RM 350
20 bottles for RM 650
Can ship anywhare in Malaysia.
Location : 8am - 5pm Shah Alam area. After 5pm or holiday Sungai Buloh, Kepong, Selayang, Subang, KL.
Contact number : P'ZI 012-4687592.
Tq.
INTRODUCING....
For petrol:
- HOW IT WORKS
1 bottle for RM 45
Tq.
