Car Brands
Car Manufacturers
Honda
DC5 Advice
<blockquote data-quote="supernova" data-source="post: 4518915" data-attributes="member: 17596"><p>There are quite a few DC5/EP3 running hardrace pillow ball front lower arm as well as EK and EG on street car. Noise is not really an issue if installed properly. Hardrace pillow ball are either delrinn lined or cover with rubber dust boot.</p><p>The tie rod end should be out in 3 -4 months time as the factory has just begin to R&D.</p></blockquote><p></p>
[QUOTE="supernova, post: 4518915, member: 17596"] There are quite a few DC5/EP3 running hardrace pillow ball front lower arm as well as EK and EG on street car. Noise is not really an issue if installed properly. Hardrace pillow ball are either delrinn lined or cover with rubber dust boot. The tie rod end should be out in 3 -4 months time as the factory has just begin to R&D. [/QUOTE]
R35 Used Titanium Exhaust
Grid Driving Vs Drift Driving - The Fastest and The Safest Driving Technic
I saw in Best Motoring video they have a group of drifters and drivers were given task to beat this one old man on track. The old man drove very cooly less dramatic and yet posted the fastest lap time among them. The...
3 common turbine?
Alrite. Need you guy's input for these 3 turbin.
1991-93, T25 turbine
TD04HL
IHI RHB5
What is each pro and con? or more suits for turbokit build? Project car will be on 1.6l SOHC engine
Replace speedometer cable
any sifu out there knows how to replace/remove the speedometer cable for satria?
mine making a lot of noise when cruising at 110km/h.
i know how to remove the front panel but never try removing the meter console...
Car Brands
Car Manufacturers
Honda
DC5 Advice
