Car Brands
Car Manufacturers
Honda
Convert option for EG sedan
<blockquote data-quote="aalto" data-source="post: 3998775" data-attributes="member: 8052"><p>yeah,....i was worried that brake fade was gonna be bad due to heavy braking, so I braked a bit earlier & a little softer. Overall the brakes lasted through with a little brake fade..using only D2, you could get some decent engine braking from its downshift, but you had to brake to a certain speed for it to happen & at some turns that meant going too slow (which was pointless).... I basically spent the whole time figuring out where & how much to brake to get the right speed & gear for the corners. </p><p></p><p>The main problem i faced was the overheating due to the radiator which also needs to cool the gbox oil ... max i could go was 4 laps before the temp. started to rise. </p><p></p><p>Arrowhead - thanx:proud:..... I was using 5Zigen Fireball, IMO the best exhaust for a kickass crossover sound...</p><p></p><p>Ad_Eg - thanx :proud:</p></blockquote><p></p>
[QUOTE="aalto, post: 3998775, member: 8052"] yeah,....i was worried that brake fade was gonna be bad due to heavy braking, so I braked a bit earlier & a little softer. Overall the brakes lasted through with a little brake fade..using only D2, you could get some decent engine braking from its downshift, but you had to brake to a certain speed for it to happen & at some turns that meant going too slow (which was pointless).... I basically spent the whole time figuring out where & how much to brake to get the right speed & gear for the corners. The main problem i faced was the overheating due to the radiator which also needs to cool the gbox oil ... max i could go was 4 laps before the temp. started to rise. Arrowhead - thanx:proud:..... I was using 5Zigen Fireball, IMO the best exhaust for a kickass crossover sound... Ad_Eg - thanx :proud: [/QUOTE]
david tao
Top Gear : The Ashes Challenge
https://www.zerotohundred.com/wp-content/uploads/2011/05/topgearashes.jpg
Top Gear invited the guys from Top Gear Australia to the UK and had a small competition amongst themselves. As the Ashes refers to the...
When have silvia club gathering?
when have silvia club gathering?:sleep::sleep::sleep:
where to get silicon blub cover?
anyone brought this kind of thing b4, which the silicon cover with light and cover the bulb? where to find it?
Car Brands
Car Manufacturers
Honda
