Car Brands
Car Manufacturers
Honda
Consume engine oil
<blockquote data-quote="k0pi" data-source="post: 1064373086" data-attributes="member: 117648"><p>May be one of the reason. I also after change cams have engine oil burnout issue despite has already fully overhauled the engine - at no common oil burnout symptom like usual (smoky exhaust, sludgy plug tip... signs of blown piston ring/scratched cylinder wall/leaky valve or plug seal). </p><p></p><p>But I did notice the engine oil decrease faster if I peak out RPM more often and gone long top speed runs, but level maintains if I drive in 'nerd' mode. The decrease can be noticed immediately after a night's hard drive. Sometimes I suspect the engine oil with little evaporation or tiny droplets sent flying under the head cover by moving parts, being sucked out from the cylinder head through the head cover breather ports (into intake plenum at higher rev & hotter condition) as logically, longer duration cams with higher valve lifts made higher vacuum flow into the combustion chamber at intake stroke along the peak powerband. Just my guess, but I rule out engine's leaking out the oil anywhere physically and visible. I would have noticed where it went.</p></blockquote><p></p>
[QUOTE="k0pi, post: 1064373086, member: 117648"] May be one of the reason. I also after change cams have engine oil burnout issue despite has already fully overhauled the engine - at no common oil burnout symptom like usual (smoky exhaust, sludgy plug tip... signs of blown piston ring/scratched cylinder wall/leaky valve or plug seal). But I did notice the engine oil decrease faster if I peak out RPM more often and gone long top speed runs, but level maintains if I drive in 'nerd' mode. The decrease can be noticed immediately after a night's hard drive. Sometimes I suspect the engine oil with little evaporation or tiny droplets sent flying under the head cover by moving parts, being sucked out from the cylinder head through the head cover breather ports (into intake plenum at higher rev & hotter condition) as logically, longer duration cams with higher valve lifts made higher vacuum flow into the combustion chamber at intake stroke along the peak powerband. Just my guess, but I rule out engine's leaking out the oil anywhere physically and visible. I would have noticed where it went. [/QUOTE]
david tao
Petronas to power Mercedes-Benz in the DTM
http://www.zerotohundred.com/?attachment_id=20218
That Petronas and Mercedes-Benz Motorsport are in bed together is not news but now the pairing have gone deeper under the sheets by extending their partnership from...
OmniTicket to provide ticketing solutions for Singapore F1 Grand Prix
OmniTicket Network to Provide Comprehensive Ticketing Solution for 2008 Formula 1™ Singapore Grand Prix
Singapore, 11 October, 2007 - OmniTicket Network, a leading provider of admission...
MME 2007: HMRT Honda Malaysia Racing Team unveils Civic Type R Race Cars
Car Brands
Car Manufacturers
Honda
Consume engine oil
