Main Forums
General Talk
Compression Ratio. How to measure it?
<blockquote data-quote="GTpuI" data-source="post: 2134802" data-attributes="member: 27522"><p>Hi ppl and sifu...I have a question about Compression Ratio. My question are:</p><p></p><p>1) What compression ratio definitely mean?</p><p>2) How to calculate it mathematically?</p><p>3) How to measure it. Are they any device to measure it?</p><p>4) What the ideal compression ratio for the engine? Is it related to piston size and shape, block size and cylinder size?</p><p>5) Is it related directly with engine performance, hp and torque?</p><p></p><p>I hope ppl, sifu, automotive engineer can give explaination. Thank you...</p></blockquote><p></p>
[QUOTE="GTpuI, post: 2134802, member: 27522"] Hi ppl and sifu...I have a question about Compression Ratio. My question are: 1) What compression ratio definitely mean? 2) How to calculate it mathematically? 3) How to measure it. Are they any device to measure it? 4) What the ideal compression ratio for the engine? Is it related to piston size and shape, block size and cylinder size? 5) Is it related directly with engine performance, hp and torque? I hope ppl, sifu, automotive engineer can give explaination. Thank you... [/QUOTE]
david tao
Who can rebuild HKS T04R?
Hello turbo lovers,
I just bought a HKS T04R. This one is the journal bearing turbo, later T04Z became ball bearing.
So who do you know can rebuild this turbo?
Thanks
4G93T Problem when Boost Kick In
Hi all sifu, wanna get advice from you all, I have the following problem after I have upgrade my fuel pump to walbro.
boost kick in then until 4K rpm suddenly turbo lag for 1K rpm range then boost come in again...
sabah/sarawak AP vs local AP
what the different sabah/sarawak Ap compare to local Ap...? as i know sabah sarawak AP more cheaper n get loan from bank less than local Ap!!!
Main Forums
General Talk
