Car Brands
Car Manufacturers
Honda
compression pressure test
<blockquote data-quote="shiroitenshi" data-source="post: 2509369" data-attributes="member: 27518"><p>Not worrying about it, because I don't mind spending on new, because I'm not going to sell the car already, probably going to keep it as a daily driver till the doors fall off.. hahaha. That's why most of the parts I needed to fix I put new stuff, instead of used, even though they're a bit more expensive.</p><p></p><p>My recent expense on clips alone were like 100++, and those were for fender liners only.. the side skirt clips are about 16bucks each (around there, I think) and the total to that was like RM70 something (because I was not missing ALL the clips, thankfully)</p><p></p><p></p><p>As for engine.</p><p>B20B can reach 9.5K, but not for long, probably a few hard runs back to back will kill it.</p><p></p><p>One unit before this got the piston 'detached' from the rod and killed the engine and head. A few other units I've seen have cracked sleeves, severe crank bearing wear, etc. Sleeved one lasts a lot longer, but the price can give you the 'peluh sejuk' feeling.</p><p></p><p>Of course, if you maintain it like a racecar, with regular stripdowns, I think okay, but for a daily driver..hmm.. better not. I'd like to see around 150K mileage before needing a stripdown at least.</p><p></p><p>But another thing floating in my head is a turbocharged B20B stock without the B16A head, using the stock head, but probably needs to be ported for better flow. </p><p></p><p>man... that would be a great engine for a daily driver, and .5 bar boost on it's 8-9ish stock CR would be very powderful as well, for a daily driver. :P</p><p></p><p>Then I'd have to look for the GSR gearbox due to the torque though (>_<)</p></blockquote><p></p>
[QUOTE="shiroitenshi, post: 2509369, member: 27518"] Not worrying about it, because I don't mind spending on new, because I'm not going to sell the car already, probably going to keep it as a daily driver till the doors fall off.. hahaha. That's why most of the parts I needed to fix I put new stuff, instead of used, even though they're a bit more expensive. My recent expense on clips alone were like 100++, and those were for fender liners only.. the side skirt clips are about 16bucks each (around there, I think) and the total to that was like RM70 something (because I was not missing ALL the clips, thankfully) As for engine. B20B can reach 9.5K, but not for long, probably a few hard runs back to back will kill it. One unit before this got the piston 'detached' from the rod and killed the engine and head. A few other units I've seen have cracked sleeves, severe crank bearing wear, etc. Sleeved one lasts a lot longer, but the price can give you the 'peluh sejuk' feeling. Of course, if you maintain it like a racecar, with regular stripdowns, I think okay, but for a daily driver..hmm.. better not. I'd like to see around 150K mileage before needing a stripdown at least. But another thing floating in my head is a turbocharged B20B stock without the B16A head, using the stock head, but probably needs to be ported for better flow. man... that would be a great engine for a daily driver, and .5 bar boost on it's 8-9ish stock CR would be very powderful as well, for a daily driver. :P Then I'd have to look for the GSR gearbox due to the torque though (>_<) [/QUOTE]
R35 Used Titanium Exhaust
FS: T-Rex CH960G steering lock
Hardly used at all. Condition 9.5/10. Steering lock with 2 way alarm.
Selling price: RM350.00. Transportation not included but can be arranged.
Please check out website for more information...
RB25 PLUG COIL for sale
Full set RB25DET plug coil for sale
Sell for RM380 neg
Intrested pls call calvin 012-2361407 or PM me
DSC01496.jpg - Image -...
turbotimer wyering
hi all the cfu's outthere....
just wanna ask anybody who know the diagram of turbo timer...mini one la.....cheap2 one la.....
like the mini turbo timer pivot la.....
i want to put it into my gen2...any idea or...
Car Brands
Car Manufacturers
Honda
