Cometic Multi-Layer Steel Head Gasket evo 1-3&vr-4
silver_knight
MD Racing
Sek27 Shah Alam
All cometic head gaskets are 4 layer MLS (multi layer steel). Cometic uses stainless steel for increased strength, it's ablity to rebound and corrision resistance. The outer layers of the gasket are embossed and coated on both sides with a flouroelastomer rubber based material designed to meet the demans of a variety of harsh sealing enviroments, load conditions, and surface finishes. This coating is also heat resistant to 482 degrees F. The shim layers of the head gakset is also stainless steel but is left uncoated and can be varied for a varied thickness. Cometic MLS gaskets are ideal for aluminum or iron surfaces will seal better than any other gasket PERIOD!
Comatic Head Gasket
86mm bore
1.3mm
Price rm399
call/sms/whatsapp
0182131320 -matt-
