Main Forums
Car Talk
Car Modification
cold air intake or short ram intake??
<blockquote data-quote="Rons" data-source="post: 795482" data-attributes="member: 15798"><p>is there any way that i can increase torque and horsepower together??..if so, which one shuld i use?? but what i see from hypertune(issue august) is quite confuse..</p><p>can anyone explain??</p></blockquote><p></p>
[QUOTE="Rons, post: 795482, member: 15798"] is there any way that i can increase torque and horsepower together??..if so, which one shuld i use?? but what i see from hypertune(issue august) is quite confuse.. can anyone explain?? [/QUOTE]
david tao
How to install Monza Tachometer in Kelisa
I've been trying to install a monza tachometer in my kelisa but i just kept failing.
The manual says i should get the rpm reading from the ignition coil but kelisa is a bit more complicated than that.
I've tried...
fuel pump
ok guys,i need to know how many lph is GSR's,VR4 and EVOs fuel pum p is?
as far as i know GSR is 80lph rite?and for VR4 and EVO is 100lph rite?me not sure bout this,so tht's y i'm asking la :)
coz i'm getting an...
DIY temperature warning light
emmm to prevent engine overheating, DIY a temperature warning light will light up when temperature over the normal by 5c to 10c.. any ideal sifu??
Main Forums
Car Talk
Car Modification
