Main Forums
Car Talk
Car Modification
Clutch Pump Problem
<blockquote data-quote="speedking" data-source="post: 512909" data-attributes="member: 318"><p>thanks for the reply bro, </p><p>but bro i think is the other way round...when my clutch is low, it is abnormally low(super low)...but when it is high is become abnormally high(super high)...</p><p>but after my mech release the air, only it become normal...the engage point is around half release of the clutch pedal...</p><p></p><p>like wat u mentioned the clutch is low if the shaft is stuck is quite logic, but how come it become super high after engine warm up? coz when my mech install the new clutch pump and when everything is working fine, the engage point is only half release of clutch pedal...weird er.... </p><p>cause if the rust has been scrape off it should become normal like half pedal to engage clutch right? </p><p></p><p>and I just change my clutch pad, clutch cover and the bearing 3 months ago... and this thing happen only after i change the above item...</p><p>now it is getting worst</p></blockquote><p></p>
[QUOTE="speedking, post: 512909, member: 318"] thanks for the reply bro, but bro i think is the other way round...when my clutch is low, it is abnormally low(super low)...but when it is high is become abnormally high(super high)... but after my mech release the air, only it become normal...the engage point is around half release of the clutch pedal... like wat u mentioned the clutch is low if the shaft is stuck is quite logic, but how come it become super high after engine warm up? coz when my mech install the new clutch pump and when everything is working fine, the engage point is only half release of clutch pedal...weird er.... cause if the rust has been scrape off it should become normal like half pedal to engage clutch right? and I just change my clutch pad, clutch cover and the bearing 3 months ago... and this thing happen only after i change the above item... now it is getting worst [/QUOTE]
R35 Used Titanium Exhaust
Dash Cams - Is It Necessary in Malaysia?
https://www.zerotohundred.com/wp-content/uploads/2012/06/DashCam.jpg
There was a time where the GPS was not around, and the maps and signboards were the only way to tell whether you are on the right track, or...
Can I go 18"??????
Hi there every1!!!!
I own a 1990 MR-2 Turbo. she's currently runnin on 17s that too when i turn i scrape the inside of the fender wall. I jus got a new paint job done along with a bodykit so every1z telln me to go...
Bcnr-33 Rb26dett
Hi all,
Just wondering how much is an RB26DETT from BCNR-33 worth? Would the engine come with transmission, or without?
Just out of curiousity. Can pm me or turn this into a topic of discussion, no worries ...
Main Forums
Car Talk
Car Modification
Clutch Pump Problem
