Main Forums
General Talk
Clutch, Brake & Accelerator
<blockquote data-quote="huakenny" data-source="post: 655962" data-attributes="member: 9770"><p>normally...clutch will broken only....accelelator very rare happen.....brake pump got to check..will leaking n cause u no break...flush clutch n brake oil if u nvr flush it.....</p></blockquote><p></p>
[QUOTE="huakenny, post: 655962, member: 9770"] normally...clutch will broken only....accelelator very rare happen.....brake pump got to check..will leaking n cause u no break...flush clutch n brake oil if u nvr flush it..... [/QUOTE]
Adaptronic ECU
Another standalone ECU that worth to consider. Check out the ECU software and it capable to handle many tyre engine.
Anyone try it before and any feedback?
Need help on Fcon RB26
does anybody know what is the model of the Fcon on original RB26....or to put it the other way....which Fcon from HKS is compatible for RB26?
and does anybody know of the price pls?
4g61t Questions
HI,
I'm seeking advice from all u ZTH sifus. I have this setup :
4g61T
Evo Camshafts
Small 16g (vr4RS)
510 Injectors
FPR
Skyline Internal Fuel Pump
SAFC 5 Button
Profec A
I know SAFC will not be able to control...
Main Forums
General Talk
