Main Forums
Interests
Do-It-Yourself Garage
Cleaning MAF
<blockquote data-quote="Andy Ng" data-source="post: 806426" data-attributes="member: 2189"><p>the proton MAF is like a box rite? inside this box is the aluminium honeycomb filter-like thingy...this is just to straighten air flow and is not the sensor itself...the sensor itself is like a small electronic component behind/after the honeycomb...</p><p></p><p>you can clean the honey comb, but be careful not to bend/crumple it...it has to be straight to straighten the airflow that is flowing past the sensor...</p><p></p><p>clean the little electronic component, the sensor itself, also...use video head cleaner spray...spray from front and back, and let it dry off...it is adviced not to scrub/rub/wipe it (unless extremely dirty with stubborn deposits sticking). also do not use strong solvents...carb cleaner maybe be too strong...</p><p></p><p>use video head cleaner spray...</p><p></p><p>one more thing...don;t bother running the car without the honeycomb thingy...it messes up everything. it has to be in there...a must to have it to straighten the air flow.</p></blockquote><p></p>
[QUOTE="Andy Ng, post: 806426, member: 2189"] the proton MAF is like a box rite? inside this box is the aluminium honeycomb filter-like thingy...this is just to straighten air flow and is not the sensor itself...the sensor itself is like a small electronic component behind/after the honeycomb... you can clean the honey comb, but be careful not to bend/crumple it...it has to be straight to straighten the airflow that is flowing past the sensor... clean the little electronic component, the sensor itself, also...use video head cleaner spray...spray from front and back, and let it dry off...it is adviced not to scrub/rub/wipe it (unless extremely dirty with stubborn deposits sticking). also do not use strong solvents...carb cleaner maybe be too strong... use video head cleaner spray... one more thing...don;t bother running the car without the honeycomb thingy...it messes up everything. it has to be in there...a must to have it to straighten the air flow. [/QUOTE]
R35 Used Titanium Exhaust
wta: Lancer floor mats same as evo8 ?
i am looking for new floor mats, can i buy original Lancer floor mats, to fit into my evo8mr ? anyone knows ? pls say something, thanks.
4g93 engine vibration- newbie
hey whats up all- i have a 4g93 out of an eagle summit i just replaced head gasket and timing belt on. the engine runs great but vibrates at idle. Timing seems to be ok. I read that you can get the silent shaft 180...
where got junkyard?
hi everyone.. :D
where got junkyard?
different from halfcut shop
junkyard is where the car is already taken apart...
i wan to find some...
i think it will be good place to source our parts for our DIY project...
Main Forums
Interests
Cleaning MAF
