Car Clubs
Car Club Categories
The MR2 MRS Club
Chronic Defect, Simple Solution?!
<blockquote data-quote="EDDYSW20" data-source="post: 1063405159" data-attributes="member: 82421"><p>Thanks for the compliments, another one I just remembered....</p><p></p><p><strong>Symptom:</strong></p><p></p><p>1. Power window operation intermittent.</p><p>2. Door lock operation also intermittent.</p><p>3. Door locks operate by itself</p><p>4. Checked the door harness until connector and all looked fine.</p><p>5. Fuses and all were fine.</p><p></p><p><strong>Defect:</strong></p><p></p><p>Opened the door harness again. Checked and all looked fine yet again. So, opened up the harness and did a 'kink' test one by one, from door control panel to both connectors. Found a few wires with the internal wire strands separated. Dalam putus, luar cantek! Cut the insulation and spliced the wires and all problems solved. </p><p></p><p><strong>Note: </strong>Kink test is when you make a loop or a sharp 'U' throughout each wire, and confirm internal wire has separated when the 'U' turns into a 'V'.....</p></blockquote><p></p>
[QUOTE="EDDYSW20, post: 1063405159, member: 82421"] Thanks for the compliments, another one I just remembered.... [B]Symptom:[/B] 1. Power window operation intermittent. 2. Door lock operation also intermittent. 3. Door locks operate by itself 4. Checked the door harness until connector and all looked fine. 5. Fuses and all were fine. [B]Defect:[/B] Opened the door harness again. Checked and all looked fine yet again. So, opened up the harness and did a 'kink' test one by one, from door control panel to both connectors. Found a few wires with the internal wire strands separated. Dalam putus, luar cantek! Cut the insulation and spliced the wires and all problems solved. [B]Note: [/B]Kink test is when you make a loop or a sharp 'U' throughout each wire, and confirm internal wire has separated when the 'U' turns into a 'V'..... [/QUOTE]
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
Litchfield GTR R35 Road Suspension Kit Absorber
original rare Yokohama ADVAN Racing RG3 18x8.5jj...
david tao
~accident repair ~touch up paint
jeff6126
Preview: TIMETOATTACK 2012: Sepang - Round 1
https://www.zerotohundred.com/wp-content/uploads/2012/05/evo_lineup2r.jpg
Neither the blazing sun nor the array of auto-related events happening last weekend could stop the crowd of speed lovers and time-attackers...
New Lamborghini
A new Lamborghini will be revealed at the Frankfurt Motorshow on 13th September 2011. There's a buzz of excitement...
WTB BCNR33 / GTR 33 Rear Diff
Defunct thread.
Car Clubs
Car Club Categories
The MR2 MRS Club
