Main Forums
Interests
Do-It-Yourself Garage
Changing Timing Belt (Iswara)
<blockquote data-quote="I3en_I3en" data-source="post: 994386" data-attributes="member: 10393"><p>bro~~~</p><p>the crank pulley(dunno19 or 21) no air gun hard to open ler~~~</p><p>the water pump also hard to take out~got 4x10mm screw on it,the pulley will turn when...u use 2 10mm tools to open the 3 nut,dont take out the screw 1st,last nut use a screw driver(enough big) to dont let the pulley run and open~~~</p><p></p><p>the head and crank got the timing marking~~~</p><p>head 1 is a triangle~the triangle the gear to the block have a line~</p><p>bottom 1 also got~but not same~lupa liao</p></blockquote><p></p>
[QUOTE="I3en_I3en, post: 994386, member: 10393"] bro~~~ the crank pulley(dunno19 or 21) no air gun hard to open ler~~~ the water pump also hard to take out~got 4x10mm screw on it,the pulley will turn when...u use 2 10mm tools to open the 3 nut,dont take out the screw 1st,last nut use a screw driver(enough big) to dont let the pulley run and open~~~ the head and crank got the timing marking~~~ head 1 is a triangle~the triangle the gear to the block have a line~ bottom 1 also got~but not same~lupa liao [/QUOTE]
david tao
Evo MR cam
Can we airtrek plug n play with evo mr cam without any adjustment?
b16a change b16b cam and valve spring with retainer problem
permalink
Need Help. currently my civic b16a change b16b cam and valve spring retainer problem.
Problem is when start car. need to press fuel for not...
wondering price of 95 R33 GTS25t with a bunch of mods...
has hicas all wheel steering. mods include: apex intercooler, greddy BOV, greddy turbo, HKS air filter, greddy exhaust, faze turbo gauge, HKS exhaust temp, water temp, oil temp, racing clutch(not sure of make). few...
Main Forums
Interests
