Car Brands
Car Manufacturers
Toyota
changing cam
<blockquote data-quote="caleb_5375" data-source="post: 3760999" data-attributes="member: 54410"><p>the cause of ur engine blow is engine mapping tak chun...as ur cam duration get higher and ur valve overlap get longer. u need to a higher compression piston to compress the intake air ...it is hard for me to explain to u ....</p><p></p><p>as ur fuel lean out the combustion chamber get dry and heat up easily...so u need to add more fuel and slightly over rich at 8-9 k rpm to protect ur engine from blow..u won't care much bout petrol when u decide go full throttle rite....</p></blockquote><p></p>
[QUOTE="caleb_5375, post: 3760999, member: 54410"] the cause of ur engine blow is engine mapping tak chun...as ur cam duration get higher and ur valve overlap get longer. u need to a higher compression piston to compress the intake air ...it is hard for me to explain to u .... as ur fuel lean out the combustion chamber get dry and heat up easily...so u need to add more fuel and slightly over rich at 8-9 k rpm to protect ur engine from blow..u won't care much bout petrol when u decide go full throttle rite.... [/QUOTE]
~accident repair ~touch up paint
jeff6126
Universal front bonnet scoop
jeff6126
Mitsubishi Lancer/inspira Evo front bonnet hood
jeff6126
Honda civic fc gtwing spoiler
jeff6126
Mitsubishi Lancer ~Evo front bumper
jeff6126
accident repair spray painting color
jeff6126
Subaru Impreza GC8
best piggyback for 4G18
hye bro sekalian,
really need ur help..
what is the best ECU piggyback for 4G18 engine since one workshop told me that
e-manage blue
afc neo
just only can adjust fuel n cant...
Servicing cleaning condenser?
i just got condenser replacement for my car.
but the inlet/outlet has not been covered when stored.
so theres some rust/oxidation like at the inlet/outlet, maybe the inner core also.
any suggestion how to clean it...
Veilside Fortune RX7 body kit
Hey there guys, for those of you who have already seen Tokyo Drift, i am talking bout the Orange Black RX7 built by Veilside
I have looked around and found out a website that sells that kit, cost 9000usd alone...
Car Brands
Car Manufacturers
Toyota
changing cam
