My Cefiro A33 3.0 don't know why only when the car is moving the aircon only cool. When it stop at the junction, the air blowing out become not so cool. Does it all the A33 having the same problem? How to solve it?
Check the cooling fans at the radiator. I had the same problem where one of the fan motor only spins at low speed. Otherwise it could be the cooling coil.
compressor going kaput....check the compressor pressure at the aircond shop...most likely it is the prob... happened to my cefiro and all the other cars b4...haha,if tat is the prob juz see whether can repair or not,if can buy a new set or recond set...
it's time for u to change ur compressor, my A32 also same problem, just change from potong kereta but is not that good, better than befor, already 3 weeks now, hope the potong kereta can change another compressor for me.
2 weeks ago got the same problem.
Happen that the Fan not spinning at Max Speed. (It's spinning!!)
Bought a motor from Chop Shop and replace it.
Now cold cold....
I encounter a problem where after full boosting ... there is a lot of white smoke blow out from my exhaust . Normal driving is fine . I heard this could be my turbo " kong " already or mayb i'm...
