Main Forums
Car Talk
Car thief prevention tips
<blockquote data-quote="jkn" data-source="post: 286545" data-attributes="member: 8652"><p>They can cut the pedal lock with a battery powered vibra-saw. Takes some time, but can be done.</p><p></p><p>As for master keys, it does not work for all brands. But it comes in a set which will work for MOST locks. That's why there are some more expensive locking systems whereby they use propietary lock that's not so common. But ANY mass-produced lock can be by-passed. At the most, you can bribe a dealer to order replacement key (like in Gone in 60 Seconds). </p><p></p><p>You can buy from most locksmith actually. They're not supposed to sell you, but it's only money right? ;) For the standard keys like ignition and door-lock, you just need a few rake-bits and a hand powered rake.</p></blockquote><p></p>
[QUOTE="jkn, post: 286545, member: 8652"] They can cut the pedal lock with a battery powered vibra-saw. Takes some time, but can be done. As for master keys, it does not work for all brands. But it comes in a set which will work for MOST locks. That's why there are some more expensive locking systems whereby they use propietary lock that's not so common. But ANY mass-produced lock can be by-passed. At the most, you can bribe a dealer to order replacement key (like in Gone in 60 Seconds). You can buy from most locksmith actually. They're not supposed to sell you, but it's only money right? ;) For the standard keys like ignition and door-lock, you just need a few rake-bits and a hand powered rake. [/QUOTE]
Some Updates: TIMETOATTACK May 19th 2013 This Sunday!
Yup, the time has...
'(00) drives Chapman's Proton: The Satria Neo Lotus Racing Edition
https://www.zerotohundred.com/wp-content/uploads/2010/08/Proton-Satria-Neo-Lotus-Racing-14-600x399.jpg
A rose is a rose by any other name and you obviously won’t get too jaded calling a spade a spade, so while we’re...
How to Read Turbo Compressor Flow Maps for Upgrade
This post is to help you get past of the "bigger is better"...
Main Forums
Car Talk
