Main Forums
Car Talk
Car got period problem....
<blockquote data-quote="ftzone" data-source="post: 383032" data-attributes="member: 9659"><p>Did u install any Oil Catch Tank? Incorrect routing of the OCT hoses may lead to increased pressure at the head, whereby oil are basically forced out from the head cover. If no such modification is done, check for blocked vacuum hoses from the valve head cover. Otherwise I suspect installation of the rocker cover gasket is done incorrectly or the mech screw it too tight. Buy original gasket it's the best.</p></blockquote><p></p>
[QUOTE="ftzone, post: 383032, member: 9659"] Did u install any Oil Catch Tank? Incorrect routing of the OCT hoses may lead to increased pressure at the head, whereby oil are basically forced out from the head cover. If no such modification is done, check for blocked vacuum hoses from the valve head cover. Otherwise I suspect installation of the rocker cover gasket is done incorrectly or the mech screw it too tight. Buy original gasket it's the best. [/QUOTE]
Advan GT Beyond 19 Civic Type R FK8 FL5 Rim Wheel
TE37 Saga S Plus 18 Civic Type R FL5 FK8
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
Litchfield GTR R35 Road Suspension Kit Absorber
Mercedes-Benz SLS AMG Roadster Vs Aston Martin DBS Volante on Wet Track!
So you happen to get stuck with a total combined power of 1081bhp from an...
Tow Truck Drift in Tokyo
Cute and funny vid
[youtube][/youtube]
Etox Zafer 1 - Turkish Sports Car
The new Etox Zafer 1 is expected to be in production in 2008 with an initial 20 cars per year to a...
Main Forums
Car Talk
