Main Forums
General Talk
car die off when braking
<blockquote data-quote="zan" data-source="post: 1714052" data-attributes="member: 9632"><p>its very common to wira 1.5 with siemens ECU. the throttle body is super sensitive to dirt sticking inside it.</p><p></p><p>easy DIY though, just remove the air filter hose. 1st u wipe with dry cloth. then clean it using carb cleaner...petroleum also may do the job.</p></blockquote><p></p>
[QUOTE="zan, post: 1714052, member: 9632"] its very common to wira 1.5 with siemens ECU. the throttle body is super sensitive to dirt sticking inside it. easy DIY though, just remove the air filter hose. 1st u wipe with dry cloth. then clean it using carb cleaner...petroleum also may do the job. [/QUOTE]
david tao
Found Tyre named VR2....lol
Found a tyre model named after my id VR2. Tyre brand Extreme Performance.....lol
https://www.zerotohundred.com/forums/attachments/568144.vB
https://www.zerotohundred.com/forums/attachments/568145.vB
where 2 service ABSORBER? JIC for r32
can dey service tein soft hard all 4 and jic complete set of hi lo?
where? how much? how long? any ideas???
Wt-know
Hi all,
when looking for an 8, what do we look for? links for models and specs if any ... as well as the do's and dont's! or is it similar when looking for a 7 as well?
thanks a lot
Main Forums
General Talk
