Main Forums
Car Talk
Car Modification
Can satria convert 4wd.
<blockquote data-quote="dinobidari" data-source="post: 967776" data-attributes="member: 19914"><p><strong>I am running Satria Gti 4 wd 450bhp dynoed on wheel</strong></p><p></p><p>Look in the post 4 my article. Lots of work...fuel tank..lots of rear end cutting and welding...don t forget to get bigger brakes..had problems stopping the car from 240-260 kph. I change ECU to Motec.. at that time 11 thou... roller bearing turbo, cams fuel rail, injectors plus this plus that..i think I spend more than 40 thou...but damn nice..only problem gbox koyak 3 times and shaft 1 time.Look at PPG gearbox..almost 30 over thou. U want also ka? I never regret. But it is illegal..but u can custom make exhaust to look like to orignal so cant see the rear..so not so obvious la... next step is 600plus bhp..but i calculate will cost almost 80 thousand...so now buying 4 digit hoping for money to do it.hahahahahaha u interested u let me know, i ask u come see my car and u can do same. now car no undercarraige..all in pieces..change to PU bushings also doing fuel lines too..running 2 walbro pumps.</p></blockquote><p></p>
[QUOTE="dinobidari, post: 967776, member: 19914"] [b]I am running Satria Gti 4 wd 450bhp dynoed on wheel[/b] Look in the post 4 my article. Lots of work...fuel tank..lots of rear end cutting and welding...don t forget to get bigger brakes..had problems stopping the car from 240-260 kph. I change ECU to Motec.. at that time 11 thou... roller bearing turbo, cams fuel rail, injectors plus this plus that..i think I spend more than 40 thou...but damn nice..only problem gbox koyak 3 times and shaft 1 time.Look at PPG gearbox..almost 30 over thou. U want also ka? I never regret. But it is illegal..but u can custom make exhaust to look like to orignal so cant see the rear..so not so obvious la... next step is 600plus bhp..but i calculate will cost almost 80 thousand...so now buying 4 digit hoping for money to do it.hahahahahaha u interested u let me know, i ask u come see my car and u can do same. now car no undercarraige..all in pieces..change to PU bushings also doing fuel lines too..running 2 walbro pumps. [/QUOTE]
david tao
NA engine light on after high rev.
Hi,
Recently i am having problem on my NA auto. The engine light on once the rev to more then 4000 - 5000 rpm.
The light gone everytime i restart the car. But it come back everytime after high rev.
Power seem ok...
advise on Brake oil change..
Thinking to change my brake DIY, undestand that the oil is drain out from the brake caliper at the tyre whereby there is a rubber nipple, and using a spana #8 to turn the screw to open the valve and let the oil come...
Looking For GTR33
Looking For GTR33 Body Partss
Hi To Skyline member.. Im looking for some R33 Parts
Here R the parts im looking for :-
-GTR33 Front Fenders
-GTR33 Front Bonnet
-GTR33 Front Lamp
-GTR33 Front Bumber
-GTR33...
Main Forums
Car Talk
Car Modification
