Main Forums
Interests
ICE
Can RCA cable read USB?
<blockquote data-quote="Waiora_ProTuner" data-source="post: 1064503408" data-attributes="member: 43825"><p>that RCA is input or output?</p><p></p><p>if input, can use extra device to read USB...or even SD and 3.5mm jack..</p></blockquote><p></p>
[QUOTE="Waiora_ProTuner, post: 1064503408, member: 43825"] that RCA is input or output? if input, can use extra device to read USB...or even SD and 3.5mm jack.. [/QUOTE]
david tao
DIY Persona : Rear Wheel Bearing
Jack up ur car
Remove wheel...
Highlights from Tokyo Auto Salon 2011
There’s no better way to kick off the new year, automotive wise, then with the...
Stiffer Engine Mount - DIY
;) See picture below.
it helps to reduce engine "rocking" during shifting gear or gas-on-gas -off.
I did this on my car. works for me. Try it.
Main Forums
Interests
ICE
