Cams for 4G93 ( what spec is better? )
My frens spec.."satria orange"..skunk 2 intake, 70mm billet throttle, Cusco exractor (jian hang copy) Bench flow head (nasty port flow usj) 240cc volume per port, block balance,micro polished crank (cost a lot of money!!),RPW valve spring,injector i dono
CAM-matspeed regrind..288..he is making 167hp@wheel torque 157NM tork..Best part..still UNTUNED!!~ )stended ecu..(mamat ni sengal sket..hehehehe)
hmmm .. i think i know that guy .. wow .. nice whp figure!
Bump:
195???!!!...i would love to see the car..who is it? whre is the car dynoed? that is mother***** high with only 288 REGRiND!!!!!!!!!!!!!! REMEMBER REGRIND got no higher lift than standed..How come it can achieved that high? 288? that power band in between 6000rpm-7500rpm...with regrind cams/stended lift....i reckon around 160++....WOW!!! may i know what's the spec? especially the compression..
Low profile, dude..low profile..it's all in the engine build with NO branded stuff but items you can buy off the shelf. His compression - 12+..go shit your pants man..in fact, he could have tuned it to 200+ whp but the stock gasket would have blown..reliability is as important as power..power band is not peaky, it's a very torquey engine, at fifth gear, still pulls like you're in 3rd, he needs more gears..
kekekeke.......292 should be ok....
304 will be lumphy on low revvv.....be carefull on the rocker height...
RPW has produced a lot of good specification for proton car..316 proven to be the best so far.....
mat speed cam not bad at all...lift i think should be ok...not that low...as they cut the bottom area of the cam as well..remember lift is at the valve not cam.....
Bump: kekekeke.......292 should be ok....
