Car Brands
Car Manufacturers
Toyota
Cams and Adjustable Cam Pulley Settings
<blockquote data-quote="cuscostrutbrace" data-source="post: 339059" data-attributes="member: 3867"><p>the vvt retards the IN cam,that means below 5000k rpm the IN cam is on advance,the the vvt kicks in,and retards the cam....that would make the overlap becomes smaller right,and as far as i know,less overlap,not good for high rpm.... :rolleyes: need to check on the net,since i heard the all vvt operates by anvancing the IN cam.BUt as far as i'm concern by reading other ppl posts on various forums,advancing the IN cam does really give much gain on the top end.</p></blockquote><p></p>
[QUOTE="cuscostrutbrace, post: 339059, member: 3867"] the vvt retards the IN cam,that means below 5000k rpm the IN cam is on advance,the the vvt kicks in,and retards the cam....that would make the overlap becomes smaller right,and as far as i know,less overlap,not good for high rpm.... :rolleyes: need to check on the net,since i heard the all vvt operates by anvancing the IN cam.BUt as far as i'm concern by reading other ppl posts on various forums,advancing the IN cam does really give much gain on the top end. [/QUOTE]
david tao
Another GTR bites the dust. Foreigner car jockey crashes on Jalan Ampang
Another GTR crashes on Jalan Ampang. This time, it's said to be a Bangladeshi car jockey who probably thought the GTR's really...
Speed signal wire disconnected.
Ok...i have an interesting question for the members....
What will happen if the speed wire connecting to our ECu is disconncted?
More detail situation. Refer to attach Url. A RSM used get ride of speed limit cut by...
tyre at MR
hey, just some of the question here!!!
the rear tyre for MR car,
izzit faster BOTAK than the front tyre?
Car Brands
Car Manufacturers
Toyota
