Car Clubs
Car Club Categories
Mitsubishi Lancer Owners Club
Camber adjusting bolt
<blockquote data-quote="BEan" data-source="post: 4182774" data-attributes="member: 5755"><p>wohooo.problem solved.found alternative already.can use proton wira lower arm camber bolt.same length n diameter.<img src="https://zerotohundred.com/forums/styles/default/xenforo/smilies/biggrin.gif" class="smilie" loading="lazy" alt=":biggrin:" title="Biggrin :biggrin:" data-shortname=":biggrin:" /></p></blockquote><p></p>
[QUOTE="BEan, post: 4182774, member: 5755"] wohooo.problem solved.found alternative already.can use proton wira lower arm camber bolt.same length n diameter.:biggrin: [/QUOTE]
david tao
Tyre on front and rear
Hi all, my car is FF, is there any problem if i use different series and brand for front and rear set? eg: 2 x continental, and 2 x toyo.
the reason is my rear set is almost botak, so i plan to use cheaper tyre to...
Toyota might tip hat to Naruse with RWD hot hatch
http://www.zerotohundred.com/?attachment_id=14157
Toyota may be working on a hot-hatch variant of the Aygo compact in honour of their chief test driver Hiromu Naruse that was recently killed in a crash while putting...
8" Speaker/Woofer in Front doors???
Sorry... posted in wrong thread! 1 Thousand apologies!
Car Clubs
Car Club Categories
