Car Brands
Car Manufacturers
Toyota
C56 = lsd ???
<blockquote data-quote="KHWONG" data-source="post: 1063813195" data-attributes="member: 32839"><p>For oem or trd LSD - either 1 side will do.</p><p></p><p>If rare item need to have 2 side to judge ... </p><p></p><p>Better take 2 side lo.... Haaha.. Good luck to u</p></blockquote><p></p>
[QUOTE="KHWONG, post: 1063813195, member: 32839"] For oem or trd LSD - either 1 side will do. If rare item need to have 2 side to judge ... Better take 2 side lo.... Haaha.. Good luck to u [/QUOTE]
R35 Used Titanium Exhaust
air filter swap question
hi guys,
need assistance.
i'm currently using a Blitz Sus Power Air Filter, and want to change to an Apexi Power Intake Filter.
the question is, if i do so, will i need to change the adapter too?
thanks in...
Ignition Timing Acceleration Adjustment
Refer to the adjustment map.........sifu's
Acceleration Ignition Map - Ignition timing can also be corrected for a rapid change in the throttle opening rate for a smoother transition into wide open throttle...
4G93P fitted with GSR turbo
just wondering are our local 4g93P blocks good enough to bolt on the gsr turbo?
thanks.
Car Brands
Car Manufacturers
Toyota
C56 = lsd ???
