Car Brands
Car Manufacturers
Toyota
BT auto trans with e-manage
<blockquote data-quote="2 Old 2 Rusty" data-source="post: 3005621" data-attributes="member: 42941"><p>You mean you've fitted an e-manage on yr BT before & you've some problem with the idling. Is that what you're trying to say ?</p><p></p><p>Yr English very deep, man. I can't understand what you're trying to say, bro. I'm only guessing.:hmmmm:</p></blockquote><p></p>
[QUOTE="2 Old 2 Rusty, post: 3005621, member: 42941"] You mean you've fitted an e-manage on yr BT before & you've some problem with the idling. Is that what you're trying to say ? Yr English very deep, man. I can't understand what you're trying to say, bro. I'm only guessing.:hmmmm: [/QUOTE]
david tao
WTB GTR dashboard monitor
i m driving a V-Spec, but my monitor start to mulfunction now. i m looking for a replacement, but i do not feel like put DEFI in as i drive around KL much and feel unsafe to use DEFI.
any idea where to get a...
Stock ecu + safc + s-itc = result ?
ok 1st of all we know that when we use fuel piggyback such as safc and fools the ecu with false signal, automatically ignition map will be screwed
now i want to know, can we 'fix' that screwed ignition map using...
DIY wideband monitoring device
You guys like to diy things?
Look here:
http://www.aces.edu/~gparmer/efi/temp/wb/guide.html#circuit%20board
You can monitor the output using a cheap digital voltmeter.
Car Brands
Car Manufacturers
Toyota
