Main Forums
Car Talk
Car Modification
Braking System
<blockquote data-quote="khoyos" data-source="post: 1958250" data-attributes="member: 711"><p>since u mentioned ur using V6TT, most likely ur running the twinpot brakes. well, each and every single twinpot brakes user (mild or rough drivers) that i know experience the same vibration problem under braking.</p><p></p><p>skimming the discs will only solve the problem temporarily, replacing disc will delay the vibration. </p><p></p><p>so there are 2 solutions, the cheap way or the expensive way:</p><p></p><p>cheap solution: just live with it, just like most twinpot users finally did. the braking power overweighs the vibration problem. just ignore it.</p><p></p><p>expensive solution: find another brake system like nissan 4 pot or other aftermarket brakes...</p><p></p><p>so ur temporary solution is to skim the rotors. hope the vibration wont come back anytime soon. once u get fed up skimming the rotors every 3 months, u will eventually get over it and just live with it.</p></blockquote><p></p>
[QUOTE="khoyos, post: 1958250, member: 711"] since u mentioned ur using V6TT, most likely ur running the twinpot brakes. well, each and every single twinpot brakes user (mild or rough drivers) that i know experience the same vibration problem under braking. skimming the discs will only solve the problem temporarily, replacing disc will delay the vibration. so there are 2 solutions, the cheap way or the expensive way: cheap solution: just live with it, just like most twinpot users finally did. the braking power overweighs the vibration problem. just ignore it. expensive solution: find another brake system like nissan 4 pot or other aftermarket brakes... so ur temporary solution is to skim the rotors. hope the vibration wont come back anytime soon. once u get fed up skimming the rotors every 3 months, u will eventually get over it and just live with it. [/QUOTE]
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
Litchfield GTR R35 Road Suspension Kit Absorber
original rare Yokohama ADVAN Racing RG3 18x8.5jj...
david tao
~accident repair ~touch up paint
jeff6126
Universal front bonnet scoop
jeff6126
Mitsubishi Lancer/inspira Evo front bonnet hood
jeff6126
Honda civic fc gtwing spoiler
jeff6126
How to make 4g64T hi rev motor??
hi all...
i hope all can give input about 2.4 block hi rev.... i'm going to rev it around 8500-9000rpm. I know base on calculation it safe only at 7500rpm..
huumm... but kiggly already proof that 4g64 with 150mm...
Kia Spectra5 SX Concept at SEMA
http://images.worldcarfans.com/articles/2007/10/31/9071031.048/9071031.048.1M.jpg
Kia Motors America (KMA) displayed its sporty new concept vehicle, the Spectra5 SX concept, at this year’s SEMA Show today in Las...
Turbine and Exhaust getting hot too fast..
I drive kau kau for 2km and pop the hood.. it seems orange (at night)
I guess it's not supposed to be like this.... why is it like this?
anyone knows?
less fueling?
oil leaking?
why?
please share me ur comments..
Main Forums
Car Talk
Car Modification
Braking System
