Main Forums
General Talk
Braking problems....
<blockquote data-quote="bOROi" data-source="post: 1410903" data-attributes="member: 3010"><p>I believe bedding in is only applicable if you replaced the brake pads, brake shoes no need to bed, but if the brakes were just serviced...meaning maybe changed new brake oil, clean brake pads then the problem cannot be warped discs especially if they were quite fine before being serviced.</p><p></p><p>I also had problems of brahe juddering or vibrating when braking at high speed even felt right up the steering column. Initially I didnt think warped discs was the problem cos the brakes were fairly new but later was advised by a mechanic that maybe the brake disc warped slightly and needed skimming, after skimming no more vibration. Warping of disc occurs if one travels fast and brakes regularly, like going in and out of traffic at high speed. This causes the discs to be heated up and if out of the blue the discs got into contact with water, whether a small pool or a sudden rain then the possobility of ending with warped disc is great, and the only solution is skimming the discs.</p></blockquote><p></p>
[QUOTE="bOROi, post: 1410903, member: 3010"] I believe bedding in is only applicable if you replaced the brake pads, brake shoes no need to bed, but if the brakes were just serviced...meaning maybe changed new brake oil, clean brake pads then the problem cannot be warped discs especially if they were quite fine before being serviced. I also had problems of brahe juddering or vibrating when braking at high speed even felt right up the steering column. Initially I didnt think warped discs was the problem cos the brakes were fairly new but later was advised by a mechanic that maybe the brake disc warped slightly and needed skimming, after skimming no more vibration. Warping of disc occurs if one travels fast and brakes regularly, like going in and out of traffic at high speed. This causes the discs to be heated up and if out of the blue the discs got into contact with water, whether a small pool or a sudden rain then the possobility of ending with warped disc is great, and the only solution is skimming the discs. [/QUOTE]
R35 Used Titanium Exhaust
Help...Problem with my engine...
Hi all,
I need help with my engine..recently I've replaced my engine top cover gasket. After that, my engine is not smooth anymore and the check engine light appear on my dash. Initially i tought it was due to the...
FC3C Tail Light For Sale
1 Pair FC3C Tail Light For sale
Price RM 450 nego
Interest Plz Contact Mr D.Y (012-2682310). Thank You
Fuel Consumption
Just curious...
Whats your fuel consumption...do share and do include what have you done to the car =)
Would love to know the FC for silvias particularly S15s and 180SX with SR20DETs....Cheers
Main Forums
General Talk
